Velocity111
dude i'm from south jersey so i'm sure we are on many of the same roads. frequently on the roads through the pines..the roads through the pines are preety decent for the most part.. just had it in chattsworth the other day at hot digity dog with the family..out dart is always loaded up.. should see it when we go to carlisle.. can't fit another thing in the trunk. yes it will sag when totaly loaded which i'd rather have then way too high unloaded.
you asked for an opinion i gave you mine. in the end its up to you on how you choose to use it.. its your car so do it however you want...
Good call.
