Removing door crash beams 74 Dart Sport
With the door off the car I drill the spot welds at one end then cut a door in the other end and pull the crash bar out in one peice. I then weld the ends back up do a little body work and paint. I strip the undercoat off the inside of the doors also.
Would it be possible to section them out without cutting the door open to remove them?Looks tight in there.Thanks for the reply
Just went for it.1st door 1 1/2 hours and 3 3" cutting discs.I angle and 1 straight grinder.1 more door to go.
I took a 2.5" hole saw to the inside of the door on my Fbody under the interior panel, removed the crash bar and stripped the undercoat and removed just under 30lbs from each door.
I was seriously thinking about doing this to my car.
Thanks for the post and pics.
How about the bumper reinforcements and shock absorbers?
Are they next on the list?
That's gotta be about a hundred pounds right there..........
It's only '73 and later that have those braces, right?
