dd70340
My 70 340 Dart is in a body shop to be stripped and repainted. The engine and transmission were removed by lowering the K member. I thought this would be a good time to replace the lower control arm bushings but the shop said they're ok and don't need to be replaced. The upper control arms were bad and I had them replaced a few years ago. I asked the mechanic at that time about the lower control arm bushings and he said that they were ok and that they usually don't need to be replaced. Is it worth replacing the lower control arm bushings now? Can I expect them to last much longer? I know it will be more expensive if they need to be replaced after the front end is put back together.
