I'm working on putting together street-able engine build using a '71 360 block with big valve stock J heads and making it a 408. In considering a hydraulic roller cam I've read about some possible issues and changes that may have to be addressed. So my question goes to all of you that have a done this, what needs to be done?
Some of the concerns and questions I come up with so are as follows:
Will the lifters bore be too short?, Are there certain brands of lifters the work better then others?
Can you use the stock stamped shaft rockers arms?
Do you need a special oil pump/distributor drive gear?
Do valve spring pressure requirements differ from flat tappet cams?
I'm looking to get as broad a torque curve as possible, and yet have a good low end response, with a fairly smooth idle. High RPM power is not my goal, but I still see some benefits from using a roller.
Thanks for you help!
