1. dad69dds
    dad69dds Well-Known Member
    81
    4
    Jul 6, 2016
    sport la
    Local Time:
    4:53 AM
    72 Duster 340 number matching with j heads wanting to buy some roller rockers not sure what will fit, don't want the best and don't want anything cheap either yes I just put a cam in her that's why im needing one.
    • Like Like x 1
    • 70chall440
      70chall440 Mopar or No Car...
      170
      142
      Jun 9, 2018
      Yelm WA
      Local Time:
      2:53 AM
      I am using PRW, seem to be ok.
      • Agree Agree x 1
      • T56MaxTorq
        T56MaxTorq Well-Known Member
        885
        287
        Dec 21, 2010
        CO
        Local Time:
        3:53 AM
        How much are you willing to spend?
        Don’t forget you’ll need to factor in shafts, a hold down/shim kit for the rockers, and custom pushrods. Not to mention the proper tools to take measurements. This alone will double cost of just buying rockers alone.
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
        16,272
        5047
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        4:53 AM
        You didn't say solid-lifter cam, or hi-lift cam,or super HD springs, etc. .......... so what is wrong with using the stock gear?
      • Abodybomber
        Abodybomber Breaking street machines , since 1983.....:) Legendary Member
        31,731
        10457
        May 21, 2011
        Arroyo grande ca
        Local Time:
        2:53 AM
        Hughes A1 prideful prices , They work... Spring pressures open and on the nose...,helps here...
      • j par
        j par Well-hung Member
        14,334
        6766
        Jul 2, 2014
        Portland Oregon
        Local Time:
        2:53 AM
        Was it a lumpy cam?
      • Garrett Ellison
        Garrett Ellison Amateur driver on public roadway, do not imitate..
        1,455
        991
        Jan 1, 2018
        Southwest VA
        Local Time:
        5:53 AM
        Budget providing, my personal favorite is the comp cams pro magnum shaft mount, Part # 1622-16, 8650 chrome molybdenum steel, shafts included, but do have to add in hold downs and double ball end push rods. When it comes to street usage, aluminum just isn't steel as far as fatigue life and oil temperature are concerned.
        • Agree Agree x 3
        • Like Like x 1
        • 72Dart6pack
          72Dart6pack Harder Better Faster Stronger.
          3,092
          2150
          Feb 1, 2016
          Roseville Michigan
          Local Time:
          5:53 AM
          I run the same rockers.
        • rumblefish360
          rumblefish360 All hail, "Kingwillrun" or be scorned by him
          35,225
          7156
          Jun 21, 2005
          New York, on a Island
          Local Time:
          5:53 AM
          If your shafts are in good shape;
          Chrysler Small Block
          If you need everything;
          Hughes Engines
          The Comps would be next in line. I have had a set on my Edelbrocks a very long time now.
          • Like Like x 2
          • B3RE
            B3RE B³ Racing Engines
            514
            446
            Aug 22, 2013
            USA
            Local Time:
            5:53 AM
            Research roller rocker geometry before you make a decision on any rocker. You'll be glad you did. Searching the archives on FABO is a good place to start.
            • Like Like x 2
            • Thanks! Thanks! x 1
            • Agree Agree x 1
            • j par
              14,334
              6766
              Jul 2, 2014
              Portland Oregon
              Local Time:
              2:53 AM
              I don't understand why everybody can't see the importance of post six? I mean that's what we really need to know correct? to make a good determination?
              • Like Like x 1
              • dad69dds
                81
                4
                Jul 6, 2016
                sport la
                Local Time:
                4:53 AM
                The j heads are original and the push rods are off set with a left and right rocker u cant run straight rockers because the push rods will rub the head casting with out taking the heads off and doing some modifications on where the push rods go through the head casting hole so a straight roller rocker will not work the cam I put in is a comp cam 20-670-4 474 intake 474 exhaust 280 i/e lift 110 seperation
              • xLURKxDOGx
                xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
                2,934
                784
                Dec 27, 2013
                PHX
                Local Time:
                2:53 AM
                AAR/TA heads? I would guess that you already have nice expensive factory rocker arms if they are offset heads. Why would you need to upgrade from them? Sell them and buy new heads and have some money leftover to grab a nice dinner.
                Jake
                • Agree Agree x 2
                • toolmanmike
                  toolmanmike FABO Staff Staff Member FABO Gold Member
                  40,080
                  22917
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  4:53 AM
                  You talking TA heads?
                • dad69dds
                  81
                  4
                  Jul 6, 2016
                  sport la
                  Local Time:
                  4:53 AM
                  Someone did a valve job and shaved the heads and that caused a low compression on a few cylinders loosened up the rocker shaft compression came up so that's why I need roller rockers
                • Demonic
                  Demonic Well-Known Member
                  511
                  292
                  Mar 21, 2015
                  Maryland
                  Local Time:
                  5:53 AM
                  Shaving the heads wouldn't cause low compression in of itself, unless the pushrods are too long now. Sounds like they are. All things equal, resurfacing the heads will raise compression. Can you cc the heads? How much was machined off? Subtracting that amount from the pushrod length would be a start.
                • j par
                  14,334
                  6766
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  2:53 AM
                  Shim the shafts...
                • MOPAROFFICIAL
                  MOPAROFFICIAL Well-Known Member
                  3,647
                  2636
                  Jun 1, 2016
                  breakwater
                  Local Time:
                  2:53 AM
                  Boy that last post is a hard read...
                  Milling would raise the compression.
                  Thicker head gasket would lower it back down, maybe to where it was before milling and possibly thinner old head gasket.
                  You need to know what head gasket was on it before and either use the same type or mill to compensate.
                  After that...measure for push rods if yours are too long
                • dad69dds
                  81
                  4
                  Jul 6, 2016
                  sport la
                  Local Time:
                  4:53 AM
                  No they are j heads not a ta both intake and exhaust are off set with a left and a right rocker non adjustable
                • dad69dds
                  81
                  4
                  Jul 6, 2016
                  sport la
                  Local Time:
                  4:53 AM
                  Oils thru the shaft push rods are solid
                  • Agree Agree x 1
                  • dad69dds
                    81
                    4
                    Jul 6, 2016
                    sport la
                    Local Time:
                    4:53 AM
                    I know that milling will raise the compression but if u don't mill the valves then u will not seat the valves because it is non adjustable rockers u cant adjust rockers get there oil from the block casting not through the push rods
                  • toolmanmike
                    40,080
                    22917
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    4:53 AM
                    Comp Cams rollers. Note the offset
                    : comp rollers.jpg
                    • Like Like x 1
                    • toolmanmike
                      40,080
                      22917
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      4:53 AM
                      • Agree Agree x 1
                      • dad69dds
                        81
                        4
                        Jul 6, 2016
                        sport la
                        Local Time:
                        4:53 AM
                        That's what im looking for tks toolmanmike
                        • Like Like x 1
                        • MOPAROFFICIAL
                          3,647
                          2636
                          Jun 1, 2016
                          breakwater
                          Local Time:
                          2:53 AM
                          You mean your pushrods are too long now.
                          • Like Like x 2
