Would my usual 10w40 oil with zinc additive be ok to use for breakin? Or should I use a breakin oil such as Brad Penn? After the 30 minute break in, when should I change the oil? Immediately or drive it a few miles or what?
very interesting read. looks like my brad penn oil isn't all that great with out an additive.
Great read & info 70aarcuda just did my cam break in and oil & filter change and just added another bottle of the comps break in and have driven it only 2 ks, Shiite $50 odd bucks wasted on oil & filter!!!.I know what ill be doing tomorrow after work....:banghead:
The motor oil testing I performed to generate the Wear Protection Ranking List, is worst case torture testing using oil testing equipment (and for the record, it is NOT a One Armed Bandit tester), which subjects the oil to far more severe loading than even the most wicked flat tappet race engine ever could.The test equipment is NOT intended to duplicate an engines internal components. On the contrary, the test equipment is specifically designed to cause an oil to reach its failure point, in order to determine what its capability limit it is.
But, a running engine is designed to last indefinitely, and of course, they do not generally cause an oil to reach its failure point. So, due to the complete difference in design, the pressures in my test are completely different, and cannot be compared directly to an engines lobe/lifter interface pressure. That would be comparing apples to oranges, which makes no sense. My testing is so severe, that the oil fails at an earlier point.
The Wear Protection test data here DIRECTLY APPLIES to flat tappet lobe/lifter interfaces (no matter how wicked the engine), distributor gear/cam gear interfaces, mechanical fuel pump pushrod tip/cam eccentric interfaces, and all highly loaded engine interfaces.
And obtaining accurate oil film strength data is ABSOLUTELY THE ONLY WAY to determine an oils wear protection capability, because an oils film strength is the last line of defense against metal to metal contact.
Thinner oil flows quicker at cold start-up to begin lubricating critical engine components much more quickly than thicker oil can. Most engine wear takes place during cold start-up before oil flow can reach all the components. So, quicker flowing thinner oil will help reduce start-up engine wear, which is actually reducing wear overall.
70aarcuda Dam..someone actually read all that...
Very interesting article... Thanks....
I always use Brad Penn break in oil, go 500 miles and use it once more for a 1,000mi. Just my .02
After reading the opinions posted here I have decided to start out with the Brad Penn breakin oil. Not sure yet what to use after breakin though. If I should go back to my favorite oil ( Castol GTX ) or stick with an oil such as Brad Penn.
There's so many problems with this article its hard to know where to start.
1) Author's name is not given. Zero credibility without that.
2) Forty some paragraphs of self promotion. The salient points could have been summarized in a couple. I did this... I did that... I AM THE GOD OF OIL TESTING... DO NOT EVEN THINK OF QUESTIONING MY FINDINGS. He uses scientific terminology in a highly un-scientific presentation.
3) His logic does not stand up to scrutiny.
Almost no description of his testing process is given other than to say its not much like an engine. I don't doubt that film strength is a critical element in determining wear protection, but there is little doubt that there are many other important characteristics.
The last paragraph points out just one of many more I could suggest. Viscosity is quite independent of film strength. There is a long list of other variables that cannot be taken into account with whatever test he is doing. One more example. He is apparently testing at 230 degrees. As he stated, most wear takes place before the engine gets there.
Its an interesting article, and I suspect there's a lot of truth in it, but his test, no matter how well designed, can only imply outcomes. Testing in engines, operated in real world conditions is the only real proof of anything.
