Show us your home made tools
I
This is getting crazy, now other people are throwing in with access to a local irrigation well head, for quickly filling the 275 gallon water tank.
Takes about 90 seconds to fill the tank with the irrigation pump and 3" fire hose, vs 20 minutes to fill it with a 3/4" residential garden hose.
They say: what you think about > expands.
I guess so....
Im thinking of using those tanks for my water supply using rain water off my 2400 SF metal roof. I have a 120 volt submersible pump to drop in one to feed my shop. I want a 1000 gallon fiberglass holding tank square or round but can’t seem to find one used.
I
If you have a small submersible pump similar to the one I have, it may not put out enough pressure to do what you want. I built an emergency water supply in our basement after the hurricane destroyed our city water system. I have two 55 gallon food grade barrels in the basement, full of clean well water from a generous neighbor up the road. I closed the valve where the city water comes in and hooked a hose from the submersible pump in a barrel to a boiler drain spigot in the basement, via a hose to backfeed our plumbing so we would have water from the tap. It works barely well enough to take a shower....but it does work. Very low water pressure even after bleeding the air from the lines. Play around with your pump in a 5 gallon bucket of water to see how it does before you invest in a big tank. That way you can work the bugs out before spending a lot of money on a tank.
Thanks, what a plumber guy said, to fix use a well-trol tank (the one with the ballon in it). The one I have was hooked up to a house and had 60 psi pressure, till house was built then on community water (10 houses on the Potomac Creek). Only use will be for washing in slop sink and maybe a toilet hooked to one of those 55 g blue plastic tanks in ground, urinal just drains down the hill on ground. Way out in county.
Darn near need to start a build thread on this Road Watering Rig.
Another flow upgrade, this time went from 1 1/4" i.d. pipe to 2" pvc i.d. pipe to feed the 3" Boom.
Made all the difference.
It is dumping twice the water that it was before and able to run in 6th gear on the JD Tractor going down the road spreading water instead of just crawling along.
Watering 1/2 mile of gravel road out front here, that includes in front of 2 other next door neighbor's places, as the Sun was going down this evening.
Used 1000 gallons of water on the 1/2 mile stretch of road.
P.S.
Oh Yeah...
No Dust as people are driving by.
P.S.
Oh Yeah...
We had the dirt road with chloride, ate all our cars up with rust. They paved it later thankfully
You might want to try to source some Lignin sulfonate, (a byproduct of the lumber industry). I've used it to pelletize gypsum and lime and to use as a dust suppressant on roads. It doesn't cancer metal, crusts over well, not a noxious smell and is water soluble. After a rain it can be reworked and packed in but a gully washer can wash it away.
Static tire balancer, make some mandrel for hub size and center cap of your rim and buy a bullseye level. Center the golf cleat and set into cup of pushrod. Stack pennies on edge to balance. Weigh the stacks and apply the stick/clamp on weights and check for bubble up. Worked better than a static balancer on the back wheels! $5 in parts and a 3D printer for the mandrels.
Improvements to an HBF bead breaker tire changer over the years. You can buy these add-ons now. Rub strips from blue barrels.
Also a bolt-on subframe dolly. Jack point is on the cg.
Borrowed a friends degree wheel. Photo copied it, then spray glued to a piece of sheet aluminum and clear coat painted it. Going to cut it out today at work and post another pic.
My clutch fan pulley holder tool.
I'm replacing the heads on my 2000 van. I'm not sure if the water pump had to come off, but circumstances made it necessary after the fact. The clutch fan would not budge off the pump pulley. I whipped this up in about 1/2 hour from the scrap pile. With this and a big pipe wrench on the nut it was a piece of cake.
These big solid roller cam double springs and dampers needed a heavy duty tool to compress onto the heads. I was not in any mood to buy that comp cam tool. The twist tool did just that when I tried it. It doesn’t need to be pretty. It just needs to do the job. Tacked up a few pieces of flat stalk and ground out a centre section attached a handle.l and off we went. Total cost near zero as this was all left overs.
Making up a Large Top portable work bench.
Nice comfortable working height and plenty of surface area for odds and ends, tools, and various power equipment.
Built a 2 x 3 frame around the perimeter to keep the plywood straight and strong to take some weight.
Hooks on the trailer side tubing to hold it in place.
Deck Sealer so that it can take some rain if it needs to sit out overnight.
Work bench deck flips to the forward half too, should the need be desired.
