I'm not sure how a photo would be helpful in this case. I probably need a bolt size chart . My manual doesn't seem to indicate the size.Photos are very helpful
I am not aware of any Mopar P/S that has a drain plug. A picture would be helpful
That's a mounting bracket hole. There's an "O" ring on the inside of that hole between the reservoir and the main pump housing. Assuming that the "O" ring is still good and in place, installing the correct bolt should cure your leak problem. I believe a 5/16 coarse bolt is correct for that hole. The length should be about 1" IIRC.This is the pump I have. If that bolt is just for a mounting hole, the leak seems to be coming in that area. When I pulled the bolt out it had fluid on it
I've checked the hoses and they seem fine.
Is there something else I could be inspecting?
It is still leaking .Thanks cudamark. I am testing it out now
To update: I took the pump out. It looked all beat up-- hammer hits, cross threaded holes-- I just replaced it with a remanufactured part from rock auto. no problems nowYou can buy seal kits for them. I bought one for my small TRW pump. I "think" I ordered it on Oreilly.com for delivery to the store. Rock auto may also have them, or summit.
