Slow build 71 Scamp 440
I’ll take it!!! Lol
Next time you can use summit racing compression calculator & you'll never need to ask again. It will get you very close.
There are other kinds like diamond c.c. but it requires much more information.
I tried it and I was missing something and wasn’t getting the numbers correctly. Is it possible for you to fill it out and screen shot the entered numbers so I can see the formula. Would be definitely appreciative.
I could try, I'm pretty dumb when it comes to that stuff lol
Compression Calculator
:thankyou:I was missing the dome ‍
Yep.
Anytime material is removed from pistons like for valve relief it adds volume so use +
Dome adds materials which subtract volume use -.
Have fun. I use the calculator a lot , for trying to come up with stroker combos and piston compression heights. Kinda cool to know
Ok we’re at hydraulic lifter and push rod stage. Should I stay off the Rock Auto site for these items? Or should I consider theses cheaper options? I realize I will have to measure out push rods to get that perfect lift.
Does anyone have recommendations?
Smith bros push rods, buy once cry once & really they're not that much more.
I would buy good name brand lifters. Such as Howard’s, Crower’s, etc. Comp has had a bad rap for awhile now that I stay away from them.
There’s a good selection in here.
Howard’s set from $159,00 and $240.00
Crower from 15.99 each.
DODGE Crower 66031X3-1 Crower Camsaver Hydraulic Lifters | Summit Racing
DODGE 7.2L/440 Mopar big block RB Crower Lifters - Hydraulic flat tappet Lifter Style - Howards Cams Brand - Free Shipping on Orders Over $109 at Summit Racing
