Small block Trick flow heads
If you had my batting average, right after you finish your project with a different set of heads...
Call and bug them, you will be doing everyone else wanting a set a favor :)
I was at the Mopar Nats. in Columbus, Ohio today. It sure ain't like the old Indy Nats.
Talked to Trick Flow about PowerPort 190 aluminum Cylinder Heads for the SB Mopar. Glad they were there, wasn't much there.
Here we go again! I was told they won't be available until the end of the year.
They also said that they were working on a single plane and a dual plane intake, supposed to come out next year.
That's it!
That's it!
That would be nice as the only good SP intakes produced are the 340Victor and Super Victor.
Trick Flow reps said they would be out by the end of the year. still testing for production
This is what they said on facebook
Indy makes an LA pattern intake? I thought just W2 style intakes.
I think i have seen them used on a Magnum head somewhere also so if they are available to fit magnums i bet the magnum mountingbosses can be cut down and holes corrected to work with a LA but thats sort of stretching it.
BTW are there no more M1 intakes? M1 singleplanes are not bad at all.
I took a few shots at the Nats. They look good but I am no judge. LOL
That's what I always thought... but, who am I ? :)
...did a quick check on Ebag.. there's 2 W2 M1's on there $300 - $450 and a Strip Dominator $225
