Charrlie_S
Slant with "one of" aluminum head
Work on the car this winter, and come to some slant six races, in 2017. Usually have a race at Bristol, and Knoxville dragway in Tn, and Clay City Ky. All not too far from you.
My 66 Valiant was built as a real low budget car. Runs 9.0's in the 1/8 and 14.3's in the 1/4 on motor. Has gone 7.8's in the 1/8 on spray. Bone stock short block.
So that's what a unicorn looks like....
I have worked from 28 degrees on up..and I honestly thought that because the chamber/cylinder was so small that not much lead was going to be necessary....but 34 is where it hits the hardest.You say the timing is locked in at 34*? If your thoughts are correct about the leverage on the crank being too small due to the angle at peak combustion pressure being too near TDC at low RPM's, and that it improves with RPM as the pressure peak occurs later when the piston is further past TDC, then isn't the solution to retard timing at lower RPM's to move the pressure peak later in the stroke? Sounds like you would benefit from unlocking the timing and putting in an aggressive mechanical advance set up.....
Can we just do that anyway without knowing how much it cost? LOLBudget build? If I told you how.much I have invested in this car, you'd call me a liar.
Cost? You mean profit. I lost actual count a while ago because of much wheeling and dealing, but I am ahead somewhere between $500 and a grand on this build.Can we just do that anyway without knowing how much it cost? LOL
The 5.7 inch 170 rod, on the 198 crank is a bolt together deal with stuff I already have on hand. The 170 block will only need some minor grinding to make it all work.If around 6.5" rod length, the Mitsu 2.6L 4G54 rods are 6.535" with a big end bore of 2.205", big end width of 1.175" and pin of .866" (22 mm), which I think may work with some machining. The crank pins could be turned down offset a bit (.050") with these to help angle and stroke. They will hold up fine to 75 HP per rod all day long. You can put in larger pins; I have some with 23 mm pins. Get the ones from the later Starions/Conquests, not from the K-cars, mini-vans, or trucks. I have put thousands of miles racing on them.
If you want shorter, more looking is needed.
We post fairly regular updates on our Facebook page, Street&Strip GarageVery cool project Tony, will be following!
Its not rocket science. At 28 degrees, it would not even squeek the tires anywhere. At 34, it would move about a foot, and then start hazing them.So you are saying that 34* gives the best initial launch? Without measuring accurately, it seems like it would be hard to call... but then again, you do this stuff all the time!
I held it at 34, because I was not real comfortable going beyond, and I don't want the N/A tune up to be radically different than the Nitrous one.
Did you check the timing marks, to make sure the damper hasn't slipped? I am questioning this, as I can't believe it would even crank over with that much initial timing, without kicking against the starter. Most N/A slants (key word "MOST") like a lot of initial advance (around 10-15*), and run best at less then 30* total. I will garuntee anything over 25* degrees on nitrous will break parts. My 66 Cuda 170 on nitrous runs between 15 and 20* fixed, depending on how big a shot. It has run a 12.905 at 101.65 mph at 3250 lbs.
We ran against that car, with my 66 Valiant, 1st round on Sat, at Clay City, Ky. last month. It flies, he was dialed 10.99 or 10.98 if I remember correctly. Nice people, and answered any questions I had. Runs an air shifted 5 speed.that 61 lancer listed in records at Asbury, Mo is local car from Carthage mo. rumor has it that it has a heavy custom flywheel and $14000 in engine. runs NA. pretty cool. I image the details are top secret!
A couple of thoughts on that.Just some more numbers for you: (Sorry, you got me started! LOL)
The rod/stroke ratio for the 170 rod and 198 crank is 1.567. Your piston speed will peak at just over 6000FPM at 6000 RPM. IIRC, that's getting up into Pro Stock pistons speed territory. (IF they use peak piston velocity as a measure....I am not entirely sure.)
Now if you wanted to push the rod/stroke ratio and forget budget limits, then a Chevy L6 (6.000") rod (SCAT makes them in H-beams BTW) with the 225 crank offset ground for max stroke would push the rod/stroke ratio down to 1.422 and the displacement would move up into the 235-240 range depending on exact boring. Max piston velocity would peak at 7000 FPM at 6000 RPM. F1 engines up into this piston speed range. So I suppose this would be a low RPM engine, but the intake suction would presumably increase substantially. A lot of big stroked motors run road/stoke ratios in this range so it is not virgin territory.
