Buy it up guys
Any idea what the weight is on the bare cnc alum sb heads? Im contemplating buying a pr and having shipped to a member for reshipping to me in Ontario.
Are they boxed decently?
Thanks
Steve
Speedmaster Promotion
My bare heads were boxed separately and then put in a big box. I would rather they shipped separately as that’s a lot of weight but I’m sure it’s cheaper that way.
Any idea(ballpark) on what the weight on yours was John? Yeah 1 pkg is cheaper than 2, but the weight of one....
Doesn't look like they have much in stock.
Mopar Chrysler SB 318 340 360 190cc 68cc Full CNC Aluminum Bare Cylinder HeadDoesn't look like they have much in stock.
you could always try Promo code : STUCKONBARGE.Thanks Brandon. Lol
That will piss off a few of our members.
Yes I just made my order but my stuff was just some distributor starter electrical stuff.. I noticed right away they were out of a lot of the Mopar small block heads... I recommend getting what they have in stock... And that's still a pretty good deal..This is only set I see for solid, flat tappet....
I'm sure you'll get the deal as soon as they get the part...Can you still get the deal if a part is out of stock.
Isn't better to buy the bare heads or buy the built heads?
Cnc heads still need to be looked over w/ a new valve job possibly correct? What about having them ported more or do the cnc flow pretty close to max?
There's really no sense in going into what their valves and springs are like because they don't have those heads for sale right now they're out of stock. I bought them with valves and springs and retainers and they've been working fine for 2 years.. I practically wasted $95 to have them checked to be told there was nothing wrong with them in the spring rates were super close to what I had already...Ok I pulled the trigger and purchased the CNC heads for 1092 shipped. I read through some old speed master threads and it says to have them checked and the valve job redone, so I will look for a shop around me to do that.
I didnt order the rockers but may circle back and buy them at a later date.
Following in the footsteps of Tony.
It looks like the only way to go if you want them...This would be a good way to go for some guys. View attachment 1715826275
