Starter wont engage
THIS IS WHY you MUST test for voltage and "voltage drop" across connectors and wiring. There is no such thing as "has voltage" but "no amperage" IF TESTED UNDER LOAD.
So one more time---------clip a meter onto the starter stud and the engine block, and check starter voltage when cranking!!!!
