abodyjoe
Presumably then, as I currently have a rimblow wheel, the Grant 846 will be a direct bolt on for my application. Hopefully MRGTX will be able to get all his needed parts.
yup
I have a rimblow wheel on there currently. It's in need of some resto. Multiple cracks and someone disconnected the rim horn activation, likely with good reason, and cut a hot in the center cover and but a horn button in it.![]()
Thanks, Joe! Yep...another $100... oh well.
Fortunately, I did get the Classic/Nostalgia 846 as you recommended.
Is the turn signal stalk the only concern? If so, bending it might be an option...especially if it means that I could get an extra couple inches of arm room.
if i remember correctly.. i think the wheel becomes too far away.. it may be comfortable for you though..
Are you sure you didn't get the soft Corinthian leather cover? ;)inexpensive leather cover
