Still not getting power steering assist
MrJLR
Built, not bought
Menifee, California
Even tried a new pump...
With new pump:
No air bubbles. ..I guess it's bled now...
With wheels off the ground and engine running, I turn the wheel back and forth and it is clearly easier than without the engine running...there must be "some" assist. ...
Put it back on the ground and it's like manual steering. ....
Pulling my hair out on this one...
Any thoughts?
Jeff
wasnt untill i went to look for the picture of that plug, i realized that was also you...didnt mean to kick you while you were down
gotcha
ok, so its easier with the wheels of the ground and the engine running then with the engine off, correct?
meaning it does assist "some" but not as much as you want
are these pumps adjustable?
gotcha
No...once the wheels are on the ground, it's like no assist at all...
I only can feel assist with the wheels off the ground...so it must not be very much at all...but it is noticeable. ...
But back on the ground it's like zero...
Jeff
with the wheels of the ground, and the engine off, is it the same or harder then with the engine on?
at some point, we need to perhaps quit looking at the pump and start looking at the steering box?
have you verified there is pressure on the output hose of the pump ?
I've been bleeding and re-bleeding, and testing and re-bleeding all day it seems...ugh.
Jeff
On the ground it feels the same engine on or off...
Everything worked fine prior to this...I don't know what could have happened to the box...?
Jeff
why did you pull the pump?
would it be possible you got one from a magnum on an LA and its running the wrong direction?
I pulled it to replace a leaking seal...
And the new pump I'm currently trying to make work it's for 74 to 76 abody mopar. ..it's an exact match to my old one...
So freaking exact that it doesn't work either! Lol
Jeff
Is the procedure to bleed the pump just turning the wheel back and forth lock to lock a few times? Could you take box to a trans shop and have them bench test it for 1200 psi pressure? Read this article on how to reduce your pressure and you'll be able to increase it too.
Moparts on the Web - Main Index
Yes....that is the basic procedure. ...and I've done a LOT of it.....
Cool link!
Jeff
Well, what about this thougt...what if there is an obstruction and that caused the seal to fail?
Pressing fluid out the only way it could go
Could be. ...I guess I'm going to have to go back to square one. ...
Pull it off...make sure the spring loaded valve moves freely, make sure there's no obstructions in the lines...etc.
Damn thing is kicking my ***...
If it was easy, everyone would do it!
I want to wrap this up because my awesome new electric fans and controller are sitting in my garage waiting for install.
This and the fans will wrap up this year's projects and I can get back to driving and enjoying her!
When I finally do get this figured out I'll let ya'll know what it turned out to be. ....
Of course, if anyone has any more ideas, I'm all ears!
Jeff
Jeff
A functional pump will bleed itself of air with only a couple of turns back and forth.
Under your circumstances I'd be checking to make sure my pressure side hose wasn't collapsed inside from moving it around during the swaps.
Under your circumstances I'd be checking to make sure my pressure side hose wasn't collapsed inside.
I kinda thought it shouldn't be this hard....lol
That's something I'll check for sure...
My high pressure hose, the fitting wouldn't screw into the port on the new pump, so I swapped out the port from my old pump to the new one... They pretty much looked identical, but I wonder if that's the issue...?
Jeff
This is the port I swapped. ..
I would gladly just buy a new power steering hose and use the new port that came with it but I don't know what type of fitting that is...
Jeff
The pump is a Saginaw PS6021
OER PS6021
The trick is getting the correct hose for my car/application. ..
There are a zillion different types. ..
Jeff
Good idea....there's actually a shop right near my work called "The Hose Man"....
Monday at lunch...!
I bet that's the problem. ..
Jeff
Not on a mopar, but i spun up a pump with my drill,the oil sure flies when its working right.
I also remember when i re sealed my power steering box in the power wagon, it was a battle,like it airlocked.
Running it with the cap off and not going lock to lock was the ticket. It would aerate the fluid if i went to lock.
