LOL....no....worked through lunch today....gonna try to over there tomorrow!Well...did you get hosed ?
Jeff
I don't "think" it's a metric Magnum type because it is "supposed" to be for a 75 - 76 Mopar.....I'm pretty sure the hose place over by my work "should" be able to make something up for me.....What you need, I think, is some "intelligent guessing." "What all" could the fitting in the pump be off from? Can we limit it to Chrysler/ Dodge/ Plymouth/ and maybe Jeep? If so, THEN you need an intelligent parts guy who can still find a PAPER catalog with the numerical/ illustrated/ pictorial guides. There are only so many kinds of fittings.........Inverted flare, which is same as used on your brake lines, transmission coolers "some years", etc.........and a couple or 4 different "o" ringed fittings used over the years. I hope you have not created a situation where the pump fitting is the newer Magnum/ metric, whatever..............
"Everco" comes to mind..........they used to sell hoses in three pieces........a tube adapter at each end which connected to a central hose of some length
The fitting you pictured appears to be inverted flare, which in my old brain, would be easier to find. Also, if you can find a hose with a good end which fits the pump, you can cut off the tube and either braze it to something like a JIC/AN hydraulic fitting, and go from there to a hose, or use a clamp on compression fitting made for the purpose. "The old numbers" for the weatherhead hose ends are 06U which is no6 hose "U" type (two braid) and 755 for 5/16 tube and 756 for 3/8 tube
06U-756:
their braze came apart in my hand trying to install....
Gotta take it back to them on Monday...
PITA.....
Jeff
Jesus H. Christ.....their braze came apart in my hand trying to install....
PITA.....
Jeff
I guess anyone can screw up...they've always done good work for me in the past. ..
I'll let them do right by me on Monday. ....
Jeff
