Stop in for a cup of coffee
Looking forward to the weekend, some states will jump 70 degrees!! Doctors are going to love that come next Monday
Saw a spot on the news this morning. Someone up north left a banana out over night. They then took it and pounded a nail into wood. Made you smile. :)
I have humidifiers on both floors. It is always 20-25% in the winter. Hot water heat doesn't add any moisture for sure.
I have two pans of water simmering on the electric stove, and a tub of water setting all the time, my home is only 960 sq feet so it is much easier to control and have at least 60% humidity
Like I said taking it easy today, not going to fall into the YouTube rabbit hole but here's just one more from that time. I love the tall guitar player on the end who adds the deep voice in the chorus and the way those three guitarists get to chunkin' those chords!!
When it gets around 15% you can spark an arc when turning on a light. (good ground path) You can make a CFL bulb flicker sometimes. LOL
Treva shocked Buddy last night, spooked both of them :rofl: that's when I realized I better get some moisture in the air
I propped the spout cap open on the tea pot. There will be moisture in a few minutes.
Here we go.
Many years ago we used a cast iron propane stove in our mobile home. Open pot of water on top wasn't a good thing with toddlers in the home. So....I simply took 4 little screws out of a cheap tea pot to remove a spring. Moisture without the whistle.
Good call. I think I will try it if I ever catch up around here. The pop fumes are pretty rich at idle. RPM it is just right. It would be nice to have them in when I scope peoples cars. I just open the door now and it helps but not enough.
On cold days, hot engine and running,hose on it actually helps warm up shop.
Yep. That's why I prop the lid open. A twist tie on the handle does the trick.
Left shop in day mode overnight,its nice in here. Car is already fixed so now its shop cleanup i guess. May do a little re-organizing.
