Cam lube works greatI like the numbers on the lower side of spec. 28-32° Dwell is the time the points stay closed. If the adjustment is 30 or just below the4 numbers will go up slightly as the rubbing block wears. Speaking of that, @halifaxhops , what do you use for point lube? I may still have a few of those little capsules that came with points.
