Guess I have to do my annual Fastenal run today and order a bunch of smalls for distrib rebuilding, should be interesting my normal guy left and I switched stores, some hard to find stuff he was able to get in for me.
ours here is by appointment only again... we're rolling backwardsGuess I have to do my annual Fastenal run today and order a bunch of smalls for distrib rebuilding, should be interesting my normal guy left and I switched stores, some hard to find stuff he was able to get in for me.
the odd stuff they tried back then
64°FMorning! minus frickin seven this morning.
You should send one to Dave DdaddyStill have a few extras. Count got corrupted somehow.
hell, i'll do you one better. @halifaxhops I'll pay ya for Dave's. just to be a good guyYou should send one to Dave Ddaddy
Just tell me when! Lube it up good with dish soap helps a lot.Good Morning Mopar Manipulators !!!
Got a late start today. Going to figure out and install the quarter regulators and windows today. I am ready for the rear window also, since I have the new gasket . Anyone install one themselves ? I put a phone call in to my glass guy but got no response. I get tired of waiting on guys. Just like this Vinyl top and headliner. I think I saw where Keith did his a while back. I have seen where the nylon rope trick works pretty good. So maybe I look around for some small cord today. But of course I will need another man to help push the glass from outside....
I used building twine. but as Hoppy said have it lubed up goodGood Morning Mopar Manipulators !!!
I got some Vasoline.....with that work ????
I got some Vasoline.....with that work ????![]()
.) I think we put his gasket on the glass first with no sealer. Then put rope caulk in the outer groove and ran the rope around that. IIRC we wrapped it so the ends were in the bottom center. So you pull rope from inside the car as someone puts pressure on the outside of glass. Putting the more difficult bottom corners in first. As for lub, I actually like Windex. Not as good as far as letting it slide, but will evaporate completely and not leave a soaf or oil residue that would prevent you from adding any sealer if it leaked.
