Stop in for a cup of coffee
I picked up a cheap lumber liquidators laminate flooring, should have gone hardwood instead. Would have been done last Sep!
I kinda like the laminate better. Easier upkeep. Cheaper, Easier to switch to different color etc.
Ray, What can I check on my gauges with my multi meter ? Just Ohm's ?
This stuff is a *** pain to get the seams right. Really do not like it at all. I know the back bed room I am going to pour leveler on first!
If the dash is out you can just hit the terminals on the back if you pull the limiter out should be good.
Just ordered a solid state limiter and a new glove box and speaker this morning. I'll Ohm them gauges out later today. Gonna strip the dash frame today in prep for new paint.
how many rooms you have to do?? I feel like I remember you posting a pic of the hallway a while back... yea?
About a year ago a pipe froze and flooded the room out and went to the hall. We almost never go in there and did not catch it right away. Been really sidetracked this year, had to re do the laundry room first then stripped a bunch of layers of whatever up from the hall and room, put the truck together also last fall and there is only so much up and down I can do on a good day so it takes forever. I feel broken today but will try to push on.
I have a limit on my daily up and down too.. :twisted:
Keith mentioned the limiters pulse. I checked one and it is pretty constant output 5VDC but I have a digital meter. Know anything about that?
Well, it seems we all learned something from my scat pack ignorance. :D
Vienna is fascinating. I've been there a couple of times, only once as an adult. My wife and I went there over a week-end a few years back. It's delightful. I have an aunt and three cousins there so I really ought to go more often ...
Good morning FABO! Sorry I didnt jump in this weekend. It was hectic around my parts, so I had to come to work to be able to chat with you guys. LOL
There is a solid state one that replaces the breaker point style. Supposed to be much better. I used on in the Road Runner Build.
what kind of oil or grease do you guys use in a manual steering box??
this one is dry dry .....you can see the little gear thingy inside and there is no grease or oil in there.
Good morning. Might I also recommend John Deere Corn Head Grease. It is a medium to light viscosity grease at ambient temps that turns to a high shear semi-flowing lube when heated. It is also a bit sticky so it coats and holds on!
http://www.greenpartstore.com/John-Deere-Special-Purpose-Corn-Head-Gun-Grease-AN102562.html
