Stop in for a cup of coffee
Frikin Car weighs a ton! Over a ton, over two tons! In the days it was built, was ok because every car had crap brakes. NOW cars stop short in front of you you are hosed.
Not feeling good this morning. I was up and down all night, barely got any sleep. The cold is settling in..
The gas company came by and changed my gas meter...
The power company showed up to get a signature to allow them to trim some brush back by the garage with the leaning pole next to it. The trimming crew will be out today and a new pole is supposed to be installed tomorrow...
As long as they clean up after themselves it beats trimming on your own!
Their chipper is broken, but I told them if the cut it up and put it aside, I can burn it in my fire pit...
The pole is right next to my back garage and is leaning away from it. If it leans the other way, it will contact my garage and maybe electrify it...
I would rather they put a new pole in, I will deal with a little debris to keep from getting electricuted...
I am back emergency grocery run. Tim were the brakes always that way sounds like something is not right.
Car is restored new by me. Drum brakes work ok but can get scary with a few hard stops. Like spirited light to light driving.
From how fast they should be better than that. Cheap or mis adjusted front shoes? When I first got the pop it stopped like the queen Mary, turned out the valve was not working right so front and back were even. I would think it would be better than that from the factory they used to tear it up.
Food for thought. thanks
Im late to the game, but Tim I would leave the Charger as is myself.
Ok guys, time for me to get out of here. Dyno here I come! I'll post my sheets later today!
I will probably leave car alone, I get this thought every time I take it out. It is Badd ***.
Good day all!
Pics were moved back in line, sorry...family kept me busy. BUT, here it is:D! Shirt makes me look skinny? (6' and 225 lb). Great knowing someone, somewhere on another continent is wearing the exact, limited shirt!:cheers:
Ters.
awesome !! good to "see" you!
Good day all!
Ters.
