Nah...junk. I have one and it needs more maintenace than my dog
This is what I have. You can't beat it for what it is. ANd you can find a used one for $50 and upSeriously thinking of getting a oil heater from a mobile home for it and a tank of oil outside.
Is it vented to the outside?This is what I have. You can't beat it for what it is. ANd you can find a used one for $50 and up
yesIs it vented to the outside?
Two wrongs don't make it right?If both cars were on the wrong side shouldn’t they have missed being crashed?
Yes but I just put the pipe through the wall. Not much more a cap on the end to keep birds from building a nest.Is it vented to the outside?
Boy....then this may not be enough. You need to insulateI have a 4" stove pipe already, the wood stove did not do crap in there.
Nope. Car coming up the hill was on the left instead of the right and turned into car you see parked . Owner moved it and parked after accident.If both cars were on the wrong side shouldn’t they have missed being crashed?
Ceiling fans?Very small stove. Yes the ceiling is killing me in there.
A couple small ceiling fans will push the heat back down.16 feet up then the arch to a metal roof! Need to get a ceiling in there.
Even plastic with Furrring strips would maka big difference and wouldn't cost a whole lot16 feet up then the arch to a metal roof! Need to get a ceiling in there.
Even vapour barrier, or sheet it in. Would make a world of difference. All the heat anything puts out goes straight out the roof vents.only other choice is a giant radiant heater.16 feet up then the arch to a metal roof! Need to get a ceiling in there.
I can't help....I am afraid of heights or anything dangerous and I would think that could be dangerousHave one. Every year I say this just never happens. Thinking that double aluminum bubble wrap stuff they make would be great and it is 4FT wide. Had the cuda in there for a long time kind of killed me. Matt has a manlift I can use also.
