Stop in for a cup of coffee
At about 5:00 i discovered the manifold was cracked....new one in morning,plus a heli-coil kit. You already know why i need that.
Driveway is a skating rink.as well as all the side roads around here.
A day of melting and now a good freeze. Back to melting tomorrow.
1962 Plymouth Savoy?
One of the max wedge cars. No wonder they chose it as a MIB vehicle.
Look at those skinny *** bias ply tires! Smoke show!!!
All that power in a 3000 lb car...
A 1962 Plymouth Savoy with a 413 Max Wedge known as the “Melrose Missile” became the first factory stock car to break into the 11 second range in July of 1962. The Missile ran a verified ¼-mile time of 11.93 seconds.
The 413 Max Wedge was quite different from an ordinary 413. In particular, the Max Wedge used different heads with 25% larger ports and bigger valves. You also got a special high-lift 300-degree camshaft, double valvesprings, a special intake manifold with 15-inch runners, and twin Carter AFB 650cfm carbs. Inside, the engine had forged connecting rods, 11:1 or 13.5:1 forged pistons, and a baffled oil pan. In Dodge cars, this was called a Ram-Charger 413, and Plymouth called it a Super Stock 413.
Rock and roll early Mopar. The 426 Max Wedge was even more fun.
Hey guys a while ago I came across a post with detailed Parts information for swapping my a904 cooler lines to braided lines. It had a list of all the parts and sizes/specs. I’m trying to locate it again or get ahold of anyone who can tell me all I need to order to do the swap. Thank you in advance.
Thanks for sharing. I never quite knew what Max Wedge is/was.
So the later BB heads were not as good as the MW ones?
Good morning, btw.
Hello Anders... :welcome:
Max wedge heads have larger ports and larger intake valves than the standard big block heads... The max wedge does not have heat crossover ports as they were for racing only and not street use... The heat crossover heats up the intake mixture when it's cold for better driveability... They left them off the max wedge heads so the race cars could get a colder/denser air-fuel ratio for racing... Colder intake charge allows you to pack more air/fuel in the cylinder than warmer mixture (heat makes things expand)... If you use max wedge heads in the winter they won't run well cold or die when you put it in gear until the engine warms up...
The max wedge was the only engine that could beat the Chevy 427 "mystery motor" of the day... When the Chevy guys saw a Max Wedge car being unloaded at the race track, they were upset knowing that their day was going to end early... :(
Was the block different, too? Are the heads interchangeable?
The blocks are not different as far as I know and you can put max wedge heads on any RB engine... The cross rams were matched ports for the max wedge heads but were made for the RB block vs the shorter B block... The heads will bolt onto a B block, but the intake ports won't match up with a B engine intake... The RB intake will not fit the shorter/narrower B engine..
The max wedge heads, intake, and exhaust manifolds were tuned to peak at 6500 RPM... They got 100% volumetric efficiency at 6500 RPM.... Before computers, back in the days of calculations and flow bench testing... It's hard to to that with today's technology. much less early 60's tech... Very impressive...
The easiest way to tell a max wedge head is to look for the lack of crossover ports... If it has crossover ports ---> it's not a max wedge head...
Good morning men, the shop is up and in the dry, all metal work is dun :) now it's time for this ol electrician to wire the place up.
Life is good on the hill this day I must say :thumbsup:
Not yet, as soon as they get built they will be hear, who knows :steering: they may be hear today :thumbsup:
