Bump!
One of the max wedge cars. No wonder they chose it as a MIB vehicle.1962 Plymouth Savoy?
Look at those skinny *** bias ply tires! Smoke show!!!
1974 and 1975 are probably that close, but I was looking at it from a biased point of view as a 75 owner ....I have never had a 74 to compare to but from I can see, the 75 is pretty much the same carThe movie studio that owns it claims 1974.
All that power in a 3000 lb car...Look at those skinny *** bias ply tires! Smoke show!!!
Rock and roll early Mopar. The 426 Max Wedge was even more fun.All that power in a 3000 lb car...
A 1962 Plymouth Savoy with a 413 Max Wedge known as the “Melrose Missile” became the first factory stock car to break into the 11 second range in July of 1962. The Missile ran a verified ¼-mile time of 11.93 seconds.
The 413 Max Wedge was quite different from an ordinary 413. In particular, the Max Wedge used different heads with 25% larger ports and bigger valves. You also got a special high-lift 300-degree camshaft, double valvesprings, a special intake manifold with 15-inch runners, and twin Carter AFB 650cfm carbs. Inside, the engine had forged connecting rods, 11:1 or 13.5:1 forged pistons, and a baffled oil pan. In Dodge cars, this was called a Ram-Charger 413, and Plymouth called it a Super Stock 413.
That is what I had in my 64 Sport Fury Convertible. Flew low....Rock and roll early Mopar. The 426 Max Wedge was even more fun.
Thanks for sharing. I never quite knew what Max Wedge is/was.All that power in a 3000 lb car...
So the later BB heads were not as good as the MW ones?The max wedge was the ultimate big block... As close to a Hemi as you can get without actually owning a Hemi...
Good morning, btw.
Was the block different, too? Are the heads interchangeable?
Is that yours?The easiest way to tell a max wedge head is to look for the lack of crossover ports... If it has crossover ports ---> it's not a max wedge head...
they may be hear today
