According to every unreliable source I could find, it's still called a snow angel.Here's an important question I need some help with. Its come up at least two or three times day. Usually in the morning and the evening.
What is the canine equivalent of a snow angel?
A bitchin frosty?Here's an important question I need some help with. Its come up at least two or three times day. Usually in the morning and the evening.
U tube is full of videosHere's an important question I need some help with. Its come up at least two or three times day. Usually in the morning and the evening.
He**, I get to see it live - usually within the first 50' of entering the park, then randomly after that - although she clearly has some prefered locations - almost never in the back yard.U tube is full of videos
Mine can be!A bitchin frosty?
That's better than a roll in the snow. LOLAccording to every unreliable source I could find, it's still called a snow angel.
There just marking there terriority.He**, I get to see it live - usually within the first 50' of entering the park, then randomly after that - although she clearly has some prefered locations - almost never in the back yard.
And Hey welcome back OMR - good to see ya postin'!
I gots one o dem.....Looks like this...View attachment 1715128274that and a bfh...
Sometime the standard lefty lug nuts are colored a light copper. For the closed end chromed ones, some have a line stamped into each point of the hex. On another set I have, the lefties use a different size socket.Yep. But when the lug nut is a closed in nut that you can't see the stud like an open lug nut, does no good
Good to know. But this was the exact sameSometime the standard lefty lug nuts are colored a light copper. For the closed end chromed ones, some have a line stamped into each point of the hex. On another set I have, the lefties use a different size socket.
Honestly, I'm wondering if it's not a case where a tire shop broke one and replaced it and simply tapped the lug nut?Sometime the standard lefty lug nuts are colored a light copper. For the closed end chromed ones, some have a line stamped into each point of the hex. On another set I have, the lefties use a different size socket.
Who knows. I don't recall any of the originals being marked different. I think it just depends on who made 'em.Honestly, I'm wondering if it's not a case where a tire shop broke one and replaced it and simply tapped the lug nut?
I've done it several times. Trailers, tractors and trucks. Just not had ones with an axle nut before.Who knows. I don't recall any of the originals being marked different. I think it just depends on who made 'em.
Definately dig through the service manuals to se what's needed to pull that drum. The only times I've had to deal with drums that required pulling was my 1960 F350 with dually and the '87 Dodge dumptruck I used at work. Both times I let someone else do it.![]()
"Get a new lug nut too."Mechanic: "Nobody has a left hander boss. What do you want me to do?"
Shop foreman: "just throw a right hander in there".
Thought about throwing my factory A body 8.75 under itOn my 64 Sport fury, I ditched the tapered axle 8.75 for a later version.
Automatic narrowed rear end!Thought about throwing my factory A body 8.75 under it
When I did my 64, 8.75's were in every wreaking yard for 100.00. Got mine out of a 69 RT charger getting scrapped...Thought about throwing my factory A body 8.75 under it
Platypus.. That's a funny word!Snow duck.
its got wings and webbed feet
ok, really it just looks like a mess, I'll call it a duck billed platypus
Yep. That or I'm gonna get a read disc conversion. I think I'll call Cass tomorrow and rack his brainAutomatic narrowed rear end!
When I did my 64, 8.75's were in every wreaking yard for 100.00. Got mine out of a 69 RT charger getting scrapped...![]()
Still waiting on my Tri-Tip!
Mopar-Man ... the local market had New York Strips ... Whole New York Strips on sale for cheapI didn't have enough room in my freezer for it all
How do you get a Dana 60, with truck axles, bearings, to fit a mopar?Yep. That or I'm gonna get a read disc conversion. I think I'll call Cass tomorrow and rack his brain
Yeah, cool part is being in the heart of Dodge Ram country, I could get a Dana 60 for about that. Then it'd be a couple hundred bucks to narrow it.
