Stop in for a cup of coffee
Well because it is a teen with a Whiplash it idles like a top fueler but doesn't perform like it. It smooths out at about 1800 rpm like grandma's Dart. He built a 360 for it and runs 12.40's @ 108.
I figured on the 318. The 360 is not bad...Have heard, read the same thing on that Camshaft. Mostly show, not much go.
I sure have an interesting Cam in my '69! Sounds kind of tame at idle, but makes over 500HP and Torque! But it has to idle at 1100 RPM!
hey, you might find this tad bit interesting. Was doing some research on those EFI kits like FAST or Holley Sniper. Seems they have minor issues running well on dual plan intakes for some reason
Sad part is, there's cams out there that'll give it that idle/lope sound and still perform
Agreed. My buddy built a +.030 440 for his Bee. Custom grind from Comp, dual plane, headers, reworked cast heads, nothing fancy. Idles nice with vacuum but dyno'd at 496 horse and 520+ torque. Perfect street engine.
Getting mixed signals?
yeah, my 408 just has a performer RPM cam in it and it has a nice rumble and lays down 437 hp and 436 ft lbs. its really limited by the heads though
One of the reasons for Direct Injection. Every cylinder is optimized.
i may have a trick up my sleeve for that one. question is, does anyone sell a stand alone computer to run a custom setup
My 64 with a 426 street wedge pulled like a train. Cant beat Mopar Big Block power IMO.
This will have great low end torque. A teener falls off pretty quick on the top end, Heads. Dont need bigger. IMO.
A friend of mine put a Holley 390 Mini-Muscle (remember those?) on his 318 Duster. Frickin thing would pull tree stumps. He is a asphalt circle track guy. The Duster was his "Street Stock". All that torque really got the Duster off the corners.
This Holley I have was designed for that. Low cube engines. Good torque down low, where it matters on the street.
I would rather jet up a small carb than try to jet down a big carb to get it to run right. Now there is a limit there.
