Stop in for a cup of coffee
Then again I was reading something today about aligning the input shaft of your trans to he flywheel to within .003" Seriously?
Thanks, now I will have to worry about that. Well, off to the shrink, I need to talk about this. :rofl::drama::rofl::soapbox::rofl:
One or two ply? Make a difference you know......
I like the stuff on a roll.
Yes all us old car guys can do it. Just heat the drum flat up with a torch, you will prob hear it pop then just press the hub through. Still wont help with the dustcap part though......
LOL was just going to say having the same conversation here
How can I separate the wheel hubs from the drums?
Never knew there was such a tool as a swedge cutter! So in theory you need one to change out the studs? Was not going there on that one.
I know how to seperate the drums from the hubs, what I didn't know was that you could use standard drums on the spindles/backing plates for the bell shaped ones
As long as the same drum size IE brake shoe dimensions are the same you can. That's why sometimes you find one "bell" on a car and three regular ones.
hmm, any idea how close to the same dimensions they have to be?
Regular Drums(closest i could find to the same spec) Bell Shaped Drum dimensions
11.42 in OD 11.56 in OD
Height 3.68in 3.69 in
10.00 ID 10.05 ID
Max Diameter: 10.06 10.09
Friction Surface: 2.90in 3.25 in
Hub Reg: 2.81 in 2.81
Bolt size: .64 in .64 in
10.00 ID 10.05 ID
well the forum changed the formatting, biggest differences are in OD and friction surfaces. is that close enough?
oh @toolmanmike if you ever do get a 64 440 car, when you're doing your parts search, use a 64 polara. Parts are identical but if you search for a 440 model, you dont get near as many results, even though they are the same car minus trim and tailights.
I think it was all the ID if I remember right. 10x2 lets say.
the brake shoes come back for both at 10 x 2.5 in. i'm thinking you're right and the regular drums will fit. They're only 27 bucks so may as well give one a try and see what happens. much better than $135.99
as for the front of the hub hitting the cap, I wonder if I can have a machine shop take the 1/4 i need and then do the smaller dust cap as suggested above
the brake shoes come back for both at 10 x 2.5 in. i'm knowing you're right and the regular drums will fit. I am seriously ashamed of doubting you but it will happen many time here to you and others That have many years of expierance and wear depends.. They're only 27 bucks so may as well give one a try and see what happens. much better than $135.99
Fixed it
You're only talking .140" difference on OD...
Do you have .070" extra clearance around the drum??? Most likely it will not be a problem as that should be clearance to the rim and should have plenty for the "larger" OD one to work...
