Stop in for a cup of coffee
Here's one for sale
Hey guys I’m looking for some bondo advice. I’m in the process of doing the steering column modification. I’ve cut off the shift indicator housing and the column shifter mount and filled the unnecessary holes with JB weld. I’m finishing the second round of sanding and smoothing today. Next will be bondo to do the finishing touches and smooth it all out. I have had absolutely 0 experience with bondo and would appreciate ANY advice!
Not all 'Bondo'/filler is the same. Some are intended for "DTM' direct to metal. So, watch that if you have layers of other stuff on there. I tried to keep my car to 1/8th inch or less. But instead of trying to lay it on perfect - I lay on a bit more than needed and use a grater file as soon as it sets up to easily shape it. For a final smooth finish use this stuff. https://www.amazon.com/dp/B005RNEZQ0/?tag=fabo03-20 Two part mix- like thin filler. Will take care of imperfections and deep scratches. If you are already very close you could just skip the filler.
Morning Mike and Tike. Yes, a chilly morning here, a little frost on the windshield.
Heading out later to watch the Grandson's do a little dirt bike practice. The two boys and Dad all race.
I remember going across Iowa after Nebraska and felt there was more Rolling Hills and Greener and more corn but again those are just veiws from the interstate.
Yep the Midwest, you can drive and see for miles down the highway.
Travel on a clear night down I-70 and you can see the lights from the next town 15 miles away.
We're a little hokie out here, but I like it.
I’ve really enjoyed the visits I’ve had in the mid-west and central parts of the country. People are great, having actual “seasons” must be awesome! However not a big fan of the heat+humidity= ugh....
