zkx14
Duster De-ruster
I'll take one, bacon on the side please.
eh, all that mayo is a heart attack waiting to happen
And possible E.coli if the vegies weren't washed...eh, all that mayo is a heart attack waiting to happen
You're right, maybe you should just have a nice healthy salad...eh, all that mayo is a heart attack waiting to happen
Stay warm our Canadian friend. It's -35° below wind chill here now. I was out after lunch to blow snow. My feet are still cold. Time for some bourbon.Just checked. -32. Likely near -40 by morning (insert profanity here)
Not looking forward to morning. Im not plugging anything in.
Reminds me, gotta go clean/reload pellet stove....
Yes, them do.Them pellet stoves work?
Compared to a regular wood stove?Yes, them do.
Have one tooCompared to a regular wood stove?
"Freestanding pellet stoves and inserts that fit inside an existing fireplace look like traditional woodstoves but operate more like a modern furnace. You need only fill the stove's hopper with pellets made from compacted sawdust, set its thermostat, sit back, and get cozy. A mechanical auger deposits the pellets into a burn pot, where they are incinerated at such a high temperature that they create no vent-clogging creosote and very little ash or emissions, which keeps both indoor and outdoor air cleaner. The best part is that they are about twice as efficient at warming your home as wood stoves."Compared to a regular wood stove?
Most can be manually fed.Yea butt....what about if the power goes out?
What have the wife turn a crank? I don't have a wifeMost can be manually fed.
A gas or propane stove will also work when the power is out...and still run off of a thermostat.Yea butt....what about if the power goes out?
No, the feed system can be either manually actuated or can also run off battery power. The feed system uses very little power.What have the wife turn a crank? I don't have a wife
Where you are, you could probably use a small wind generator to recharge the batteries.No, the feed system can be either manually actuated or can also run off battery power. The feed system uses very little power.
It would work, but you need to reduce the ceiling height and use low speed blowers to recirculate the air and even out the temperature.So if I wanted to hear a 40x80 shed, good choice for the pellet stove or no?
