Pretty old school how they are made, never even thought about using one in the field, just did not know about them.
Nice that's the way to do it. My daughter is turning out to be a decent wrench asks a lot of questions.Today is oil change school.
Best friend’s daughter is bringing a friend over to learn how to service her F150.
Will teach her about inspecting various things and help her understand what goes on in most garages.
Educating someone will maybe prevent the typical “you need an injector flush “ and all the other hooks the service writer tries to set.
I am tired of weed eating the banks around here so I thought I would use an old sickle bar mowerPretty old school how they are made, never even thought about using one in the field, just did not know about them.
Mine goes on a couple times a year to cut the grass and shrubs in my line of spruce trees. I use a chain hoist to hang it on the tractor, its so cumbersome.I am tired of weed eating the banks around here so I thought I would use an old sickle bar mower
I'm sure the people at the banks appreciated your weed eating tho..I am tired of weed eating the banks around here so I thought I would use an old sickle bar mower
The pitman,in case something locks up. The drive end of the knife probably has a ball/socket that pops apart if you hit something that wont cut. If i tag a tree, it disconnects and swings away.That one will do it for sure. Might grab ron today and see if we can get it on the tractor. Why do they use a wooden bar to run it? In case you hit metal?
What tractor do you have? Those things were used by model Bs and above. 540 rpm pto shafts.I saw how big it is. If it is too big for yours it is too big for mine....Ha ha ha there you go Boys
The wood piece is not the tailboard, its part of the drive system. Size of a hockey stick.The board is on the end of the mower blade. It pushes the fallen weeds away from the next swath so it does not plug the mower up. You can mow without it. But depending on what you are mowing you may have to get off and unplug it. And Hoppy that thing will mow small trees, animals, fingers and hands! Shut the tractor off if you have to unplug it
Oh...I forgot that one. I have not seen this thing and ws assuming the one on the end of the mower by looking at the picturesThe wood piece is not the tailboard, its part of the drive system. Size of a hockey stick.
I replaced mine, was like 20 bucks. If bearings pile up, it fails.
I totally forgot that one. TJ is right. I will give you the money for it . I think you will like it HoppyKen told me they have them at tractor supply under 20 just have to measure it might just pick it up today just to try it out. Kid did a good job on it from what I can tell. Hell he took the money and bought a tractor with it!
Morning Pete. Still have snow up nort'?Good morning, watching deer and the return of the Orange Bellied Black Birds......Robins
How big? I've got wood.Totally different design. The board runs the blade with a ball socket like tj mentioned. Have to see if I have some oak around to make it.
Haven't checked the update, but we could have the biggest snow of the year on the first day of spring.Yes we now have snow after a mostly brown winter. My drain field froze up, fun times. How about you.
Most is melted away. We got a dusting yesterday. I had both cars out of the storage garage and tempted to go for a cruise but it needs to rain a couple times to clean the salt off the streets. Good to hear them run though.Yes we now have snow after a mostly brown winter. My drain field froze up, fun times. How about you.
