GeorgeH
Morning, nothing here yetHey.....Its Snowing here!!!!!!!!!
Good Morning...........
I may have some pictures up on my website. OMR knows the place that did some cusom work on mine. There's some limites due to the construction but yea, go for it if you want. We used seat back frame from a '70 or '71 for latches and headrest.Well, I started looking at doing a custom front bench seat for Victoria This is the bottom front I am trying to see if I can save a bit on buying and shipping cost on Buckets, and look and see how this does ... What are your thoughts ?
That would be great for me. I'm most comfortable with a truck. LOLIt will be cool though. Still will need a longer handle but that's the easy part.
A little different but think Road Runners came with bench and 4 speed.I am pretty sure they make a bench seat shifter for either trans.
Hey Ray.Morning Matt
Don't know if this is same...Hey Keith I found a repair kit!
CAMPBELL HPK-1 Hydrant Yard Repair Kit | eBay
Project "Shart" 1967 Dart GTYeahhh... I borrow that , from my buddy's shop , when I need it... Can't justify owing one.....Nice set up tool Mitch!
Hey TMM!
That's mandatory for gm? You have a case spreader also?Yeahhh... I borrow that , from my buddy's shop , when I need it... Can't justify owing one.....
Case spreader? I need that for the wife!That's mandatory for gm? You have a case spreader also?
Drive problems? Did you do a defrag?Man this CD drive is killing me thought I found the problem it is better but still no go. Have to bring it to your house and have the tennents fix it!
It will be cool though. Still will need a longer handle.
It's dumping the white stuff here. Probably another 3 inches since last night but didn't get going again till around daybreak.Hey.....Its Snowing here!!!!!!!!!
It is mandatory to set any new pinion in a case, All makes and models. Ya don't get the pinion depth right, you might as well not even try ti install a new set. I always get by, without the case spreader. Takes a little more time ,That's mandatory for gm? You have a case spreader also?
