Stop in for a cup of coffee
That is some gooooood info right there ....Thank you Thank you Thank You
Here's something else that's useful, the water pump from an LA will bolt on, which flows more than the poly pump. However, the inlet and outlet are switched In some applications.
Today is lawn cutting day.... The neighbor's and mine need a cut....
Tomorrow we are meeting my friend Ron and his daughter at the Michigan Dunes for a beach day... :D :D
Nope. I got a complete running drivetrain for 100 bucks. People nearly give them away.
Actually hold the phone
I just ran the vin through a decoder and it is saying it is an LA 318
In 66 ????
I thought the LA came later
But according to an online decoder
PH23E6 is an LA
Somewhere on the lift it says not to use ladders. I’m not. He is..
Dumb and dumber hard at work...
In 66 ????
PH23E6 is an LA
Pre67 you can't trust the decoders. I tried that and it said my polara should have a 400... which didn't come out until 72.
Simple way to be sure, look at the valve covers. If it has bolts on top of the valve cover, it's a poly
In 66 ????
PH23E6 is an LA
Like this
Notice the bolts on top of the valve cover?
I can't get the hood open yet, the latch is frozen
Got the carb rebuilt today... finally..
. and mine is running again... so far lol.
This is when I was cleaning it... notice how clear the carb cleaner is????? lol
