Looks good Keefer!
Or I could just sit here and replay the morning traffic report a few timesLooks good Keefer!
Maybe some were under it, but assuming most of them were on it. I guess that's why new standards require bolts and nuts through the house boards and not just lagged in. hi timmyHey guys....
Maybe, Maybe Not. Maybe, Maybe Not.So you are NOT going to Carlisle? Or you are?
I've never tried it, but I've always been told you divide the compression test PSI by 10 to get your ratio...Question for all you smart people out there......How to calculate the compression ratio of an engine that is complete? I know compression test gives you psi, but what about the overall ratio?
DONT re-up!!!Maybe, Maybe Not. Maybe, Maybe Not.
I'm waiting on a single signature from a CSM in my unit to confirm. He's had the request for about a month now. He's kind of playing games with it, trying to use it as a bargining chip to get me to reenlist...
Not planning on it. I'm using it as leverage in negotiations anyway. They are hurting bad numbers wise across the board and I am literally the only one in my MOS that is qualified. Losing me, actually cripples them because of the type of unit they are, they can't pull anyone into it. Only get in by soldier request only.DONT re-up!!!
Air pressure is 14.7 psi at sea level. Therefore, you divide the total measured pressure by 14.7 to get the absolute compression ratio.Question for all you smart people out there......How to calculate the compression ratio of an engine that is complete? I know compression test gives you psi, but what about the overall ratio?
Danm Dave, you are smart.....Air pressure is 14.7 psi at sea level. Therefore, you divide the total measured pressure by 14.7 to get the absolute compression ratio.
147 psi would equal 10.1 compression ratio.
On sort the same subject, of being smart, how accurate is an IQ test online? I took one yesterday, 131 IQ. Was timed and looked legit.Air pressure is 14.7 psi at sea level. Therefore, you divide the total measured pressure by 14.7 to get the absolute compression ratio.
Take it from someone who has been around for a long time.Not planning on it. I'm using it as leverage in negotiations anyway. They are hurting bad numbers wise across the board and I am literally the only one in my MOS that is qualified. Losing me, actually cripples them because of the type of unit they are, they can't pull anyone into it. Only get in by soldier request only.
They can be reasonable but often aren’t as accurate as a true IQ test which is conducted using many more tests such as spacial relations and pattern recognition components. I have never seen a good on line one that includes those things. The on line ones are usually just knowledge based and that is only part of a true IQ test.On sort the same subject, of being smart, how accurate is an IQ test online? I took one yesterday, 131 IQ. Was timed and looked legit.
The test I took had spacial relations and pattern recognition on it.They can be reasonable but often aren’t as accurate as a true IQ test which is conducted using many more tests such as spacial relations and pattern recognition components. I have never seen a good on line one that includes those things. The on line ones are usually just knowledge based and that is only part of a true IQ test.
Oh I know. I'm just repeating what they're trying to sell me onTake it from someone who has been around for a long time.
No one is indispensable, no one.
I once thought that I could never be replaced.
That did not hold water.
I see a lot of them online that are not only just knowledge based, but limited to one subject. My understanding of IQ is that it’s more about concepts than specifics about people, history, etcThey can be reasonable but often aren’t as accurate as a true IQ test which is conducted using many more tests such as spacial relations and pattern recognition components. I have never seen a good on line one that includes those things. The on line ones are usually just knowledge based and that is only part of a true IQ test.
There were no questions about history or things like that...http://www.iqtest.dk/main.swfI see a lot of them online that are not only just knowledge based, but limited to one subject. My understanding of IQ is that it’s more about concepts than specifics about people, history, etc
Boss said i could have the day off. So i got drunk the night before. Phone rings the next morning,boss wants me at work.Take it from someone who has been around for a long time.
If I would have had 20 me's , I would not have needed 40 employees...Boss said i could have the day off. So i got drunk the night before. Phone rings the next morning,boss wants me at work.
I said no, i’m hungover. He replies you’re not indispensable...
I replied “imagine that” go ahead and replace me.
Three years, no raise. Im not being pushed around. When i did finally quit, he hired two people.
Go figure.
