Stop in for a cup of coffee
Haven't you left yet? You are not coming are you? Carlisle awaits
Guess you didn’t see earlier post. Couldn’t get left this afternoon so I took long nap. I just now got everything fully packed and loaded. Leaving here shortly. Should be there when the gates open at 7
I saw the earlier post but you are procrastinating and I was sure you would have a longer drive than 7 hours
Right at 8 nonstop. I’m figuring 8.5-9. As I will have to stop for fuel once. Leaving here within about an hour.
And yes, I am a procrastinator at times. But don’t worry, I will be there.
It will take you between 9-10 hours. You have some weather in your way that will likely cause some serious fog as you get past Wheeling WV that will slow your speed.
Its getting intense outside.
Power should go out any time. As it always does. Lights just flickered.
Radar...figure 40-45 minutes of this...
Good Morning dream chasers!!
Have a safe trip. See ya when you get here.
Car Show starts today and for the most part runs through Saturday.
You in the show field Craig? I'll look you up today.
You all have fun in Carlisle...
I have a busy weekend...
Graduation party for my niece on Sunday and then meet with Ron at the beach...
Younger kid is home and we will be working on his engine.... We should be able to install the pistons and then see what else we can get done.... Measure the compression and decide which heads to run, then install cam, degree cam and make sure it's in the right position, then measure the compression... If things go well, we may be able to get the intake and oil pan on it...
Then I have to install the lifters and rocker gear in the 340 for my brother's Challenger.... Then decide on the intake and install the oil pan...
My lawn needs mowing sometime this weekend...
Other than that, I have nothing to do....
We are R111 best directions street past Subway down by Gate 3 67-69 stock row.
Cheryl’s been looking for you.
