yay!!Your off mine!
yay!!Your off mine!
Almost. Little icy outback. But rain next couple days. Good MorningWERE SLIPPING!
Yep! It all started after I retired and really came into play after my heart surgery! For instance, my wife and I were talking about collector cars. I told her "I'm not done yet. Don't be surprised if I come driving up in something different one of these days." Irresponsible? If you say so. LOLHave you ever thrown what is responsible out the window and done you wanted to instead?
Morning all.
Far too often! Lot of fun, but it's been a bit costly!Have you ever thrown what is responsible out the window and done you wanted to instead?
Morning all.
.Your X wife?Far too often! Lot of fun, but it's been a bit costly!
Thats an interesting looking ride.
Gotta do what you gotta do. Those extractors are hard as the hob knobs.So my map gas torch isnt hot enough to get the gallery plug out. What do yall think about hitting the plug with a welder where I broke the extractor off at to heat it up?
Morning all.
Thost tapered pipe plugs can get welded in there for sure. If they are female square, it's a good idea to stick some square stock or an extension in the hole and wrap it with a hammer. It upsets the threads and often times makes it easier to remove. If there's sealer a little heat can help.From the "Now for something completely different" file.
That gallery plug is what? Like 3/8 pipe size? And heat had no effect. Hmmmm
Enough of it exposed for a sharp cold chisel to get a bite on?
I used to service a engine rebuilding shop. The young guns had square plug sockets broken every week. The old guy that stripped the blocks rarely had a twisted or broken plug socket. I asked him what he did different. He taught me that trick.From the "Now for something completely different" file.
you told your wife ahead of time, that now makes it responsible, right? you will have to try harder Mike!
What was I thinkin!
My wingman just texted me to remind me it's Friday the 13th. "Stay close to the house!" he says![]()
