You **** stirrer....![]()
That's why I usually stay out of those, many of the keyboard experts with different opinions try to argue against logic....
It’s a funny thing when it comes to assembling an engine. There’s so many different accepted approaches. In both internet form and book form. For example, last week there was the discussion about which order to put the pistons in my 440. One book says start at number 1, then go 7,2,8,3,6,5,4; the other book says start at 3, go to 6, 4, 5, 1,8,2,7 and then the 1980s Haynes manual says 3,4,5,6,1,2,7,8 .
Then the same books, have 3 different orders for torquing the mains and setting the thrust bearing, then on top of that, the Haynes book shows the anchor slots being on opposite sides on the rod from each other, but if you do that, the oil holes in the bearings don’t line up.
crazy crazy
Well it’s also decades of passed down information and at times conflicting information.That's why I usually stay out of those, many of the keyboard experts with different opinions try to argue against logic....
I do not think it matters in what order they go in, just WHERE they go in matters!!I put them in 2,4,6,8 then tilt thee block the other direction to get the other 4. Easier for me and even with hose on the rod bolts, less chance of a mishap.
working in that test cell for cummins, engine break in was a hotly debated topic everytime until Cummins finally put a policy in place. Every engine is brought to operating temp, then broken in. Then as sample, every 100th engine is started up, rev’d to 1800 RPMs where Max torque is stock, then sat there for an hour, if it was still running after that, the batch was determined good. If not, it was torn down and sent back to engineering
I might have missed a rod bolt/nut torque one time. In a 460 boat engine. All I know, it threw a rod on breakin. Well, not actually threw a rod, just a rod knock.... Do not know why....Only failure I ever had.....Of course in a boat!! PITA to take back out......Just do them in pairs on the same crank journal...
Whatever order is easiest for you to keep track and make sure you don't skip any or leave the nuts/bolts loose....
I might have missed a rod bolt/nut torque one time. In a 460 boat engine. All I know, it threw a rod on breakin. Do not know why....Only failure I ever had.....Of course in a boat!! PITA to take back out......
The fun ones to watch for me were the torture tests. Cummins takes their engines, no oil but the assembly lube. Hooks them to the test cell dyno. Set them at 1800 RPMs, run them 24 hours at load, which draws about 25 pounds of boost, or until they blow up, whichever occurs first. Most of the time, the engines make it to the 24 hr mark. The things are junk by that point for sure. And rattling themselves apart.Same at the engine plant that I worked at...
The dyno room would always warm the engines up before running the program... Part of their program was revving to 6000 rpm, and another part was 1/2 hour at wide open throttle.... They did a 10 hour run with different RPM's involved, then tore them down, verified torque on all fasteners before loosening them, and inspecting the parts for wear after they were torn down...
I did similar on my 440 over the weekend. Checked it 3 times, the 2nd and 3rd I got the idea to mark each nut with a different color paint marker just to check myselfThat's why when I built Eddie's engine with him, one of us would torque the rod or main, then the other would go right behind and double check...
By the time we were done, each nut and bolt had been checked 6 times at least (Three passes each) and there would be no question that we didn't get one....
Yep, it was in a jet boat.....Glastron....And this happened a long time ago, at least 28 years....I have learned since then....I knew a guy that had gone through 3 of those 460s on his jet boat![]()
How many horse?![]()
Love his music..Santa Ana
Why are they cutting your power1:00, right on the button. They cut the power. I just remembered. Had to scramble and get the inverter connected to pellet stove.
"Pay you bill or will will be forced to cut your power"???Why are they cutting your power
where do I sign up!!It's only free if you're too lazy to work!
Maintenance. A scheduled outage. My kid must be going nuts, its been off for 33 minutes.Why are they cutting your power
