Stop in for a cup of coffee
:D
Gee, Monday looks like it’s gonna be just swell!
A foot of snow and 50 mph winds...yuck.
Ours is supposed to start tomorrow about noon. A wintery mix then snow till about noon on Sunday. Wet heavy stuff.
We are winding up a full blown Nor’easter. Secondary low to form off the coast and crank up the snow machine. Historically, storms like these can dump up to 2-3’ of snow before they are over.
We are still 2 days away from the start so it won’t surprise me to see the predicted amounts go up significantly between now and then.
I hauled the electric snow blower up from the basement and put it in the garage as a measure of anti-snow insurance...:p
Goodevening!
Was an interesting day at the new job. A lot of information to take in. Not a lot went on here today i see.
So. Swapping in a 408 magnum based small block. Everywhere you read motor mounts will work. Just have to shim the drivers side. That is bunk. The teener block has 4 mounting holes. Only three are used tho. On passenger side on this block only has three mounting holes. You guessed it. 318 uses the rear hole. This only has the front hole. Had to cut modify right motor mount.
