They are yours......I'll take em Tim...Thanks
Standard in California..................or they should be...............bunch of crazy sum bitches on the road.........
I believe it is to prevent dieseling. Should go to direct manifold vacuum. To slow idle on shutoff....Question.
Thermoquad, vacuum dashpot for idle stop. Why and how?
Why is it there and how is it plumbed?
That’s what i figured. Will work on that tomorrow. Think its been running without it, but i tested it and it works.I believe it is to prevent dieseling. Should go to direct manifold vacuum. To slow idle on shutoff....
Us too!Good morning and we have a hell of a problem here...we're out of coffee!!
Thank the coffee gods Mickey D's opens in 10 minutes and only a mile away.![]()
The plan so far is after we're done with demo paint the floor. Left front corner an L shaped work bench. Along the left wall is where the lift will be placed.You figure out your layout in there now? Looks great!
Not yet but someday.That works are there stairs to the loft also of just that access hole?
Those pull down stairs work, had them in a few houses I owned easy install also.Not yet but someday.
With the pitch of the roof there is lots of room to walk around. It's already insulated with plywood flooring. Just need to add a few lights.Those pull down stairs work, had them in a few houses I owned easy install also.
