Unconventional
It's Wagon Wednesday!
Good morning
Good morning
Now for something completely different!
I'll bring back 2 large adult beverages just for me while they do that
I'm on my way before it's gone. LOLWith a shopping cart no doubt.![]()
I knew it.I'm on my way before it's gone. LOL
Have ya seen his liquor cabinet? Holy crap. I crawled out last time.I knew it.
No way your just walking aisle.![]()
Got a mopar number? Maybe.All caught up, again.... Good morning. @halifaxhops you have a set of NOS for my 66 4bbl 383? In the satellite?
I'll look....Got a mopar number? Maybe.
I knew it.
I came home with 2 different Bulleit barrel picks and a bottle of Obtainium which is also a barrel pick. It is called "Light Whiskey" but it tips the proof scales at 139.4. Man is it fun stuff.Have ya seen his liquor cabinet? Holy crap. I crawled out last time.
Might be...Milage better also?![]()
The 770 you’ve been fighting?Installed a 650 DP Holley on 408. Had better low end response. So I'm ordering a new 650 street avenger carb for it. New 770 carb will be for sale...
Check ball was gummed up. Bad fuel. Good nowThe 770 you’ve been fighting?
Should never need a 20 ton press to install a u-joint. But whatever gets it done.Finally got the stubborn U joint installed thanks to a 20 ton press. Now I can finally drive my new truck!
Normally yeah. I took it all back apart, all the pins were where they should have been, so I put the caps back in, a slight press with the press and they popped right into place. Not sure why they wouldn’t go in other Wise.Should never need a 20 ton press to install a u-joint. But whatever gets it done.
I use a small flapwheel in a drill to shine up the bore and lube before pressing in the caps. By pressing i mean hammer.Normally yeah. I took it all back apart, all the pins were where they should have been, so I put the caps back in, a slight press with the press and they popped right into place. Not sure why they wouldn’t go in other Wise.
I’ve got a a small emery stone on the die grinder I polish it with. I normally use pop them in with a big C clamp, never failed me before.I use a small flapwheel in a drill to shine up the bore and lube before pressing in the caps. By pressing i mean hammer.
Hmmm what you wanting for it?Check ball was gummed up. Bad fuel. Good now
