Stop in for a cup of coffee
Yup, hardware/software issues.
So my iphone has 256 songs stored in it. My old phone has 990. So what has transpired to remove so much music from my library? Well i connected with apple, and they have no clue or wont tell me. Example, these 4 albums are on my old phone. Only one shows up on new phone. The technical support people have no solution.
Loaded old phone into my pc,and tried to get it on new one. Music on pc disappeared. Frustrating. View attachment 1715960932
Dark side of the moon for the win!
Triumph rock and roll machine, max webster.
My top ones were walter rossi,and charlee. Waaay ahead of lenny kravitz
Well ****.
Yesterday I was filing out the air bleeds in the carb trying to lean it out a touch. I did the inner bleeds on the secondaries and it made it pick up and rev out like a bat out of hell.
Did the primaries, and as I was pulling out of the garage my brand new aluminum radiator sprung a leak. No fixing it. its leaking from the cores and the shop said its not possible to fix it. all because a radiator hose spring got sucked into the radiator somehow.
Now i'm trying to find a stock radiator instead of a new aluminum one since they're so thin.
Well ****.
Check with another rad shop. A couple tubes could be welded shut,no big deal.And throw that damn spring away. Jeez.
I called every place up here and the last guy I talked to said the last person who did it up here died. then said good luck and hung up.
Have to change them through the wheel wells above the tires. The number 3 plug is so close to the steering column. Took an hour just to change that one...But got it done... Now a cold beer , and head up for a shower.......
