What i got going on is while engine is at operating tempature and in park if i rev it up to 2000 to 2500 rpm it will start to sputter and surge but then when i go up further to 3000 rpm it straightens out and stays good all the way to 6000 rpm. Also when i am driving it there is not surge at all this only happens while its in park or nuetral. Whats going on here? Engines is a 360 magnum carburetor is a 600cfm manual choke edelbrock carburetor. Timing is good all ignition parts are new including the distributer. I got the initial timing set at 16 degrees total timing set at 34 degrees all in by 2800 rpm and it starts to come in around 1500 rpm. Any help would be great this is confusing me.
I have seen this issue when driving but never only when in park or nuetal. Could it be the float level being off? or fuel pressure to high or low? never seen anything like this before. Normally when the engine has a load on it the surge will be worse but the surge is totally gone while driving and present while in park or nuetral.
