suggestions on repairing lower rear shock mounts
hotairgypsy
Albuquerque
well i discovered both lower rear mounts on my car have broken off threads...so of course the shock will slide on but no way to secure it...i did order a replacement parts and they were not a good fit for the shaft diameter to the shock..i did go to the junk yard and try and find a new set of lower mounts but didnt have any luck...i did find some top one and thought about just mounting them in but they are longer than the lower ones...so what have others done to repair this properly if you all dont mind me asking...
Start a parts wanted ad for some and replace it.
If the new "pins" are too big, machine them down so they are the same size as the original ones. Then have the new pins welded on.
We fix them all the time using the upper shock bolt . cut it off and weld one in place. That is a 7 1/4 shock plate I have one . $15 plus shipping. Sould fit in a $9.95 flat rate box.
With a welder, anything is possible… unless you’re welding hardened bolts on, in which case the weld will actually destroy the temper of the steel.
