The mighty 318! Help with compression, and head/piston combos…or even a stroker!
590 HP 318'' .............the dyno was EXTREMELY happy. i call major BS on it
All it takes is the right cam and your car can be scary fast too!
heads what makes the power, c.i. and stroke and cam dictate at what rpm it dose it, gonna need more head than 302s to get where you wanna go, ant enuff meat in them to port them enuff 375 to 400 bout best theyll do and be lucky to do that and not leak water!! ask steve duluchie...lol ...more stroke gonna need even more head to feed it too... speed cost, how fast can ya afford to go???
I think some of you are missing the fact this post is just a troll post. I think it's the same guy who was gonna bore his block with a mag drill and cut his piston tops with a band saw.
i hadn't seen that thread but i am willing to watch someone build that motor :)
It was hilarious. I cant remember the name of the thread, maybe someone else does and can link it for us.
See this is why i like this place.. everyone has their own ways of getting stuff done... i personally put the piston/rod in the block then trim it with a belt sander.... Zero deck.. every time :)
He has a video on surfacing a head with a car battery on a cinder block, with a sheet of sandpaper. No kidding. And another where he teaches you to check bore geometry with a carpenter square. No kidding.
yeah.. i only watched him for a short while... he went on a rant about new cars sucking and i was out.... guys seem to forget 100k on a old car was not near normal.. i love new cars for daily driving...
Saw the cinderblock one... and i have done some shady **** to get a car together to just drive when i was like 16.. not at 50 though. (well not as bad) :) But that one was bad...
I found this Hot Rod article.
AHH thanks for posting that..i have had guys telling the problem with my engine is that i'm over-cammed... mine is almost identical to that one cept on 109 instead of 110... feels good to know i wasn't far off :)
also the author of this amazing hit piece:
in fairness... ford actually made a boring machine that bolted into the head bolt holes to do the model t engines... but yeah... 100 years ago
I have a Kwikway boring bar, doing engines in the field/at industrial installations wasn't uncommon, not just Flatheads. Like anything else, the quality & results are 95% operator skill & attentiveness.
