Some days you get a lot done, some days you don't, today was a good day.
Today I had Sam (sawcut64) come over and help me start putting the body back together. We got the doors back on, the hood on, and finished up installing the bushing kit in the hinges. Let me tell you, those bushing kits are worth every penny of the $15 they cost! The doors open smoothly and have no droop, creaks, or squeaks. If you have not done it yet, do it! This also marks the first time the doors have been back on since May of 2007. Its starting to look like a real car again!
Of course, I had to put the Hemi scoop on the hood, just for a little motivation.
This morning I did a little mock up work on the engine, bolting things together and making sure they will work. I ran into a few issues, the dipstick tube was cracked at the bottom, of course, me being a cheap-***, I fired up the welder, welded the cracked part, then put it to the grinder. Good as new.
I noticed that the chrome Mopar timing cover I bought absolutely disappears behind the damper and water pump housing. Oh well.
I also have issues with the stock throttle cable bracket and trans kick down. The RPM intake is so much taller than the stock intake, that the bracket is almost 2 inches shorter than it needs to line up with the Demon carb. I will need to cut it apart, make some extensions, then weld it back together. Another issue was that I replaced the stock rod style trans kick down with a Lokar cable style kickdown, this is completely different, I need to weld on a new bracket for this to work. The stock on-intake coil location will not work with the new Demon carb, the bowl hits the coil, I guess I will have to mount it on the fender. This why its a good idea to mock things up before you drop the engine in.
Also on the list of things I did today, I finished assembling the sandblast cabinet and fired it up with glass bead, I proceded to blast my RPM intake (it was painted blue), it now looks like a brand new cast intake.
