Thanks giving was a busy day, besides cooking everything, I also was spraying base and clear. Looking back, I probably should have waited for another day, but since the temp was over 65F at noon, I decided to go ahead. I sprayed base quickly, and went inside to get the Turkey in the oven, when I was done, I went back out and wet sanded any dust and junk in the base (my fault, I got the gun too close to the plastic sheet and stirred up a whole lot of crap). I went back inside and started prepping the sides and noticed that the turkey was cooking faster than planned (see, small breasts are not as good as large ones!), so now I was rushing. I waited until it was done, pulled it out, and wrapped foil over it, shoved the sides in the oven and told someone to pull them out when the timer goes off. Now, back out to the garage, I started spraying the clear, 45 min later, I was done. Now back inside for cold turkey. :-D
Not everything goes as planned. Since I was in a hurry, and the weather conditions were not as good as the last time, and really tight quarters caused me a few problems.
This was the first problem, the pass side front corner of the hood. Since there was only about 2 feet between the corner and the front fender for me to walk past, and that is about how wide I am, I brushed the corner while I was clearing the first coat, while spraying the second coat I noticed this, but I thought it was in the clear, not down to the base, unfortunately I was wrong.
At that point, I finished, figuring I would have to fix it later anyway.
Again I did the same thing with the pass fender. :angry7:
And again on the top corner of the pass door. :angryfir:
And to top it all off, since I was rushing, I got a major run in the pass fender, about 10 inches long. :crybaby:
I got a lot more orange peel in this application than I did when I sprayed the body. I learned a lesson, there is no room to rush when doing paint, especially clear. All is not lost, I already sanded down the bad spots and re-shot the base, today I am going to spray a bit of touch up clear over it. I will then have to wetsand everything. Next learning project, BUFFING! :book::dontknow::study:
