Thermo quad float bowl adjustment
Fuel and Air Systems
  1. Tad
    Tad FABO Gold Member FABO Gold Member
    207
    96
    Jun 19, 2018
    Temecula
    Local Time:
    9:45 PM
    Hey guys, I looked for some other threads related to this but couldn’t find anything. I rebuilt my thermal quad recently. All new gaskets, o rings, everything! Got it back on the car and ran OK but noticed the gaskets between each piece wet and some fuel overflowing. I did not adjust the float bowl levels. I’m thinking this is why I’m having the excess fuel. Can someone post some basic directions on how to do this?
  2. RustyRatRod
    RustyRatRod Weenie idiot loser. FABO Gold Member
    58,502
    28913
    Jun 7, 2010
    Georgia
    Local Time:
    12:45 AM
    Did you replace the floats? There was a huge batch of brass floats that hit the market that were soldered on the stems upside down. There's a "notch" in the float and that's supposed to end up facing down into the carburetor when assembled, which means the notch would face UP when being assembled with the top upside down. If that made sense.
    • Agree Agree x 1
    • Tad
      207
      96
      Jun 19, 2018
      Temecula
      Local Time:
      9:45 PM
      I believe mine are the black floats if I remember correctly. It’s an early 70s thermo quad
      • Like Like x 1
      • Tad
        207
        96
        Jun 19, 2018
        Temecula
        Local Time:
        9:45 PM
        I did not replace the floats
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        46,792
        31057
        Jan 18, 2006
        Iowa
        Local Time:
        11:45 PM
        Hate to be a downer here but you didn't "overhaul" your carb. You should have checked the floats and adjusted them correctly according to the instructions in the kit. It's all part of doing the job right. I suggest you take it back apart and do it right. If you need another kit, so be it. lesson learned.
        • Like Like x 1
        • Agree Agree x 1
        • Tad
          207
          96
          Jun 19, 2018
          Temecula
          Local Time:
          9:45 PM
          I know. I don’t mind taking it apart again to make it right. You are right, Lesson learned
          • Like Like x 1
          • 66fs
            66fs Well-Known Member
            4,357
            1184
            Sep 9, 2009
            Greenwood, South Carolina
            Local Time:
            12:45 AM
            I always replace the black plastic floats with brass ones. I have seen and used the ones RRR is talking about. Just adjust the hight, for whatever you use, per the instructions provided. The plastic ones can eventually soak up gas changing characteristics. The early TQ used brass floats and later changed to black plastic.
            • Like Like x 1
            • Agree Agree x 1
            • Tad
              207
              96
              Jun 19, 2018
              Temecula
              Local Time:
              9:45 PM
              So I have the carburetor taken apart again. I mean completely taken apart! I’m wanting to really deep clean it this time. I’ve read that boiling either lemon water or vinegar with the parts is a good way to clean them. Any other suggestions?
            • toolmanmike
              46,792
              31057
              Jan 18, 2006
              Iowa
              Local Time:
              11:45 PM
              I have never used lemon or vinegar but it should work. I like to run a tag wire through all the passages to make sure they are clean.
              • Agree Agree x 1
              • Tad
                207
                96
                Jun 19, 2018
                Temecula
                Local Time:
                9:45 PM
              • 66fs
                4,357
                1184
                Sep 9, 2009
                Local Time:
                12:45 AM
                Those are good.
              • Tad
                207
                96
                Jun 19, 2018
                Temecula
                Local Time:
                9:45 PM
                Thank you. The carb is specifically a 9126S. I wasn’t sure if there were specific floats for this or if that would work.
              • 66fs
                4,357
                1184
                Sep 9, 2009
                Local Time:
                12:45 AM
                The TQ floats work for all TQ's as far as I know. They are measured differently if I remember correctly, but the measurement should be in your kit or with your floats.
              • pishta
                pishta I know I'm right....
                16,497
                6182
                Oct 13, 2004
                Tustin, CA
                Local Time:
                9:45 PM
                tqfloatadjustment.jpg D-D84INzCU6b0Pm7yPOLhO8Y-bnFGgKXb1lY-CzctEL7C5ftd0vbzUzN1w8iY1k2wWABLcR6how2rGGT35IW8OoPnkB_tOpf.jpg
              • Tad
                207
                96
                Jun 19, 2018
                Temecula
                Local Time:
                9:45 PM
              • pishta
                16,497
                6182
                Oct 13, 2004
                Tustin, CA
                Local Time:
                9:45 PM
                naa, just "TQ float spec" on a search.
                • Like Like x 1
                • Tad
                  207
                  96
                  Jun 19, 2018
                  Temecula
                  Local Time:
                  9:45 PM
                  just got everything back together again. I checked the float measurement which is supposed to be at 23 mm from the base of the gasket to the bottom of the float. Mine was at 32 mm. Way out of spec. I believe these are actually new floats and I never set them. Lesson learned.
                  • Like Like x 1
