Yup.RRR, can he use the older style housing ?
You said a mouthful there.But um, what do I know ..........
IIRC, the cl-to-cl of the mounting flange bolt spacing is "tighter" than the pre 80's thermostat housing.Good to know, mines an 81 D series.
I sanded it flat, reinstalled with a new gasket and a little rtv. Fingers crossed. If it still leaks I'll pick up the correct housing.
A few flurries this morning, snow on the ground from yesterday. Quite the change from Friday and Saturday!Good luck and best wishes with everything there! How are you managing to staying dry there? It’s not too pleasant out on this side of the state today… well, we’re dry because the snow is powdery and a cordless leaf blower does the sweeping really well.
Why is your throttle return spring trying to open the throttle (floor it per say) ???Apologies in advance for all the pictures, for the 340 throttle cable bracket and summit kickdown cable installed. The kickdown cable doesn't match the instructions, which is great and Summit so far ignored me explaining this to them and asking for clarification.
That out of the way, does this all look correct:
View attachment 1716513872View attachment 1716513873View attachment 1716513874View attachment 1716513875View attachment 1716513876View attachment 1716513877Wh
Things I'm not sure about ... The silver spring looks really stretched, it goes from the bottom of the summit kickdown bracket. The other thing is the throttle cable (I crudely drew a red line on the last photo) but is that ok looped up like that? I think before it was maybe looped down.
Going to relocate the brake booster to the rear port on the carb so I plan to remove that vacuum tree and cap that hole. Also need to pick up caps for some of the small holes at the front of the intake.
I'm hoping that the linkage is correct though.
I'd put the heavier spring going forward, ditch the second spring. Never tried hooking up a Lokar kickdown myself, but I don't see why you would need the second spring, as the Lokar cable appears to me to be hooked directly to the carb without any free play.Well, clearly something is wrong
There's a second spring going forward (you can see it in the pic below, but the kickdown rod is now gone and there's a 340 bracket installed). That darker spring is connected to a bracket at the front of the intake and then the big loop on the carb.
I'm not entirely certain what the 2nd lighter colored spring is for unless they're both throttle return springs and with one stretched they are fighting each other.
Heavier spring for throttle. The lighter spring is the return for the kickdown. They both need to be used.Well, clearly something is wrong
Hook the throttle spring into the middle of the cable end yoke. It doesn't look like you have any tension the way you have it now.Hopefully this looks better, dark throttle return spring going forward, lighter silver spring attached to kickdown
View attachment 1716513944View attachment 1716513945View attachment 1716513946
the idea of the kickdown having a return spring was due to the linkage having the long slot in the adjustable rod. It was to ensure the linkage returned to the end of the slot. You have a cable. It will return with the throttle. What you have now is the two springs which you should have returning the throttle, not the kickdown cable.Hopefully this looks better, dark throttle return spring going forward, lighter silver spring attached to kickdown
For sure, in this case I no longer have that slotted rod, so essentially as posted in #318 both springs are acting as throttle return springs due to having a kickdown cable.If i can chime in. The purpose of the kickdown spring(outermost) running from throttle stud to the rear(somewhere, I cant see it) is to bring/hold that slotted arm so that it JUST touches the throttle stud when its at idle. Then as you increase the fuel the slotted arm pushes back on connecting linkages.
Hope that helps/makes sense?
Correct. The cable doesn't need a return spring, because it's on the opposite side of the carburetor pivot point, so it uses the carburetor return spring for its return. It's even more important to have the cable adjusted correctly, too.For sure, in this case I no longer have that slotted rod, so essentially as posted in #318 both springs are acting as throttle return springs due to having a kickdown cable.
That's one of the things to work on next, going to zip tie the throttle wide open and check cable tension and make sure the lever is all the way back at the trans.It's even more important to have the cable adjusted correctly, too
