NC Engine Builder
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 7,248
- Reaction score
- 12,264
I have built a handful of them, they work fine, yeah the bigger bore of the 360 and 340 is better, but in a mild street build it doesn't matter.
I agree. 318s have always been total workhorses. They're like Rodney Dangerfield. They don't get no respect. I've always liked um.I have 2 ea 318 mag and 360 mag blocks here, none currently a running drop in option. I must say im beyond tired of those that say to scrap a. 318 BECAUSE it's a 318. Stock wise I've had better service out of 318s than 360s. Stock wise from my experience I'm more likely to say ditch the 360 than to say ditch the 318.... Just my experience over the years.
But since I have both here and the application is a truck, AND I have to build up whichever one I decide to use, I originally figured I'd do a 360 and fix what I have found (for my usage anyway) to be what I haven't liked about 360s in general.
But since I do have both here and I haven't bought any parts yet just kicking ideas around
Cool. So is stroker 360 an option or just stock stroke 360? Do you have crankshafts for either motor?I have 2 ea 318 mag and 360 mag blocks here, none currently a running drop in option. I must say im beyond tired of those that say to scrap a. 318 BECAUSE it's a 318. Stock wise I've had better service out of 318s than 360s. Stock wise from my experience I'm more likely to say ditch the 360 than to say ditch the 318.... Just my experience over the years.
RRR likes to be in control!
I’m pretty sure you know I’m not anti 318, but to me we’re not talking about 318’s a 390 isn’t a 318 anymore, your stated goal was low end torque aka displacement, to me we’re talking 365 vs 390 vs 408, a 365 can make decent low end but if more is needed/wanted than a 390 gonna make about 30 tq more and for similar price 408 will make 50 tq more than a 365, obviously there could be other factors but for the dollar per lbs-ft the 408 would be the wiser move. But if you chose 390 or even a 323 that’s up to you and I’ll try my best to help with whatever choice is made.I have 2 ea 318 mag and 360 mag blocks here, none currently a running drop in option. I must say im beyond tired of those that say to scrap a. 318 BECAUSE it's a 318. Stock wise I've had better service out of 318s than 360s. Stock wise from my experience I'm more likely to say ditch the 360 than to say ditch the 318.... Just my experience over the years.
I currently have the stock crank for allCool. So is stroker 360 an option or just stock stroke 360? Do you have crankshafts for either motor?
It ain't about thatRRR likes to be in control!
Hardly.RRR likes to be in control!
I don't think that the hp or torque increase just based on displacement increase alone is accurate. If we're talking same EVERYTHING else between one CID and another.. carb intake cam heads ignition EVERYTHING then maybe... But stroke it then that means bigger cam, different carb, may head work you wouldn't have "wasted time on" on a stocker and that's all out the windowI’m pretty sure you know I’m not anti 318, but to me we’re not talking about 318’s a 390 isn’t a 318 anymore, your stated goal was low end torque aka displacement, to me we’re talking 365 vs 390 vs 408, a 365 can make decent low end but if more is needed/wanted than a 390 gonna make about 30 tq more and for similar price 408 will make 50 tq more than a 365, obviously there could be other factors but for the dollar per lbs-ft the 408 would be the wiser move. But if you chose 390 or even a 323 that’s up to you and I’ll try my best to help with whatever choice is made.
Hp ain’t overly connected to displacement but torque is, a decent built street engine gonna make around 1.15-1.25 lbs-ft per cid depending on the build so say 1.2tq:cid, that’s around 365/438tq 390/468tq and 408/490tq give or take some lbs-ft’s.I don't think that the hp or torque increase just based on displacement increase alone is accurate. If we're talking same EVERYTHING else between one CID and another.. carb intake cam heads ignition EVERYTHING then maybe... But stroke it then that means bigger cam, different carb, may head work you wouldn't have "wasted time on" on a stocker and that's all out the window
Check your numbers.1.2tq:cid, that’s around 365/438tq 390/368tq and 408/490tq give or take some lbs-ft’s.
Is a 360 stroker on the table then?I currently have the stock crank for all
It ain't about that
Krusty says NoIs a 360 stroker on the table then?
4" stroke and a 3.910 bore, right? That's a big difference. That added .090" to the stroke instead of making the bore 4" is adding 74 cubes.In this case though I don't think that were talking "under square" by enough to matter
Doesn't mean all 3 would make the exact same torque to Cid ratio but should be fairly close to each other, making the difference in torque somewhat consistent between the displacements. Obviously the 408 should peak at lower rpms than the 390 than the 360.the difference in torque is that consistent?
I agree to a point.It's a ridiculous argument saying to go with a 340 or 360 block. Use what you have and have fun.
Then use a 5.2 Magnum.I agree to a point.
It sure makes sense to use a roller block if you can find one. The roller LA or Magnum is a great way around flat tappet cam and lifter troubles.
I have an LA 318 and 360 that I may never use.
