Ticking noise, 383, can't locate the source
What two plugs were missing? You should have had zero oil pressure with two plugs missing.
that's the crazy thing. motor had 60 psi cold and 40 hot. of the 6 in the block, only had 4. cam plugs behind the plate. rebuilt it had the Same oil psi...
Those plugs aren't 100% necessary. The cam retainer, unless warped badly, will provide more than enough restriction. Still, plugs are more reliable than just the plate.
agree, but a 340 page helped me identify it, so I rebuild engine with all 6. like I said, it still ticked until longer pushrods.
