Tubular Lower Control Arm Thread
sooooooo...I take it you're still incorporating the strut bar?
Yep. The strut rod is on the same exact plane as the pivot. I have tested this. I have snugged everything down and cycled the arms well past their intended travel and there is no binding. Smooth.
Damn John, that looks sweeeeeeeeeeeet!! The Dog leg looks really strong too!
Thanks Louis. The only part that sucks is we won't get to use those cool 90* gussets that I ordered. On yours I am going to go ahead and incorporate a sway bar mount in the gusset that will go on the inboard side. It actually works out perfect that the sway bar mount will be no more that drilling a hole in the gusset. Sweet.
That's ok I will stand them up and use them for the Lower Shock mounts, I better order 2 more! haaaaa:D
Good Idea on the sway bar, the mount will be hidden when someone does not want to use it, good stuff going on here!!
Awesome Idea on the shock mounts.
The sway bar mount will be hidden in some speed holes too, so it will blend right in.
luv the design...what's your thought on doing away with the strut bar?...is it needed with the design of the lower control arm you have come up with?...I'm thinking it's only function is for the braking force?
....just spittballin
I like them there because, like you said braking force. I think it will take some for the stress from the rear of the K member and move it towards the front where the strut bar attaches. I think they will be strong.
Melted some metal last night.
what are all those things that look like fish scales?....nice work!
me to......
just havin a little fun...no need to take yourself so seriously.
BTW ,...the name is Denny
Here is what I have come up with for a gusset and sway bar mount. It will be cut out of 1/4" plate. I'm taking it in tomorrow to get a quote on having them cut. Any thoughts?
I am also debating about adding another gusset that will extend all of the way past where the ball joint attaches. I need to check clearance.
Looks good just like that. Do you think there is a need for another gusset? That tube is basically solid from where the dog leg ties into the main arm. I think it should be Hella strong like you have it!
Are you going to fully weld the gusset or stitch weld it?
The end of the arm where the tapered hole is just as thick as the factory cast part. My biggest concern is you pulling the wheels for 200'. Lol. Seriously it would make me feel better and would put peoples minds at ease. I have received a couple of comments about it.
Interesting, I am curious to see how it looks. Do you think it will clear everything when you steer the wheel? Safety is first for dang sure!
